Velocity of Spring: Solved 2m/s
  • Thread starter Thread starter Batman4t
    Spring Velocity
The problem involves a spring that is stretched and attached to a block on a frictionless surface. The original poster seeks to determine the speed of the block when the spring returns to its unstretched length after a force is removed.
  • The original poster attempts to calculate the speed using work-energy principles but questions the validity of their result of 2 m/s. Other participants raise concerns about the completeness of the problem statement and the accuracy of the work calculation.
Participants are actively discussing the problem, with some suggesting that the original poster clarify the question and assumptions. There is a recognition of the need to correctly calculate the work done by the spring and the potential use of conservation of energy principles.
There are indications that the original poster may have misunderstood how to calculate work done by a variable force, as well as the need for clarity in the problem statement regarding the speed measurement point.
Batman4t
[SOLVED] velocity of a spring
https://wug-s.physics.uiuc.edu/cgi/courses/shell/common/showme.pl?cc/IAState/phys221/spring/homework/05/block_spring_nofriction/4.gif
A spring is stretched a distance of Dx = 40.0 cm beyond its relaxed length. Attached to the end of the spring is an block of mass m = 8.00 kg, which rests on a horizontal frictionless surface. A force of magnitude 40.0 N is required to hold the block at this position. The force is then removed.
When the spring again returns to its unstretched length, what is the speed of the attached object?
http://wug.physics.uiuc.edu/cc/IAState/Phys221/spring08/course%20info/FS.pdf
change in X=.4m
mass=8kg
F=k*dx
calculated k=100N/m
w=f*dl
work=.5mv^2
v=?
projected v=2m/s
How come 2m/s is not working for my speed did I make an error?
Your problem statement is incomplete. What's the question? At what point are you looking for the speed (if that's the question)? Also, calculating work as the given force of 40N times its displacement is not correct. We can assist further once you clarify the problem and note all givens, and have made another attempt at a solution.
Sorry, When the spring again returns to its unstretched length, what is the speed of the attached object?
I solved it:
Using the spring constant that I found:
F(x) = kx
I found the new Work (W) done for the new distance using:
W = (1/2)k(x2)^2 - (1/2)k(x1)^2
Then with the new amount of work done used the equation Wtotal = (delta)K. So...
W(new) = (1/2)m(v2)^2 - (1/2)m(v1)^2
Starting form it's stretched point the velocity is zero so you're just left with
\sqrt{2}
OK, I see what you may have done, you set the work done by the spring equal to the KE, which is good, but you incorrectly calculated the work. The spring force is variable (it is 0 at the unstretched length), so you can't use a constant 40N as the force...what shouldyou use? Or it is better to use conservation of energy, since only conservative forces are involved..
Edit: OK, you got it.
  • · Replies 16 ·
  • · Replies 20 ·
  • · Replies 21 ·
