Velocity of current-carrying cylinder
The discussion focuses on calculating the exit velocity of a current-carrying cylindrical rod rolling on parallel rails in a magnetic field. The initial attempt at solving the problem involved calculating torque and using the moment of inertia, but the resulting acceleration was found to be incorrect. The correct approach includes determining the net force from the magnetic interaction and friction, leading to a refined acceleration calculation. The final velocity formula is derived by substituting the corrected acceleration into the kinematic equation. The key takeaway is that the mistake stemmed from an incorrect acceleration value, which affected the final result.
steve B. 98
A cylindrical rod of length w carries a current I as shown(perpendicular to B) and is bathed in a field B perpendicular to the plane in which is a " shaped rail. The rod rolls without slipping on the rails, its length perpendicular to the two parallel rails and equal to the space between them. It starts at rest and rolls off after going a distance L. Show that its exit velocity is ##v = \sqrt{ \frac{4BLIw}{3M}}##
##F=B \times I w=BIw##
##\tau=r \times F##
##\tau=I\alpha##
[/B]
I start by taking the torque
##\tau=r \times BIw##
Using the moment of inertia for a cylinder I get
##\tau=Mr^2\alpha /2 ##
##\alpha=\frac{2BIw}{Mr}##
since the problem was rolling without slipping we get.
##a=\frac{2BIw}{M}##
Using ##v^2=0^2+2as##
##v=\sqrt{\frac{4BIwL}{M}}##
But this is off by a factor of ##\frac{1}{\sqrt{3}}##.
What did I do wrong, and some hints toward the solution would be nice.
easy question pal i have solved it and i am placing the pictures.
First find net force which is force on wire by current and field and second is frictional force which will rotate it and hence net force is IwB-f which is Ma .
Then find torque which is fr=Iα when you will sove net acc. to be 2IwB/(3M) place it in v^2=2aL you will get the answer.
your acc was incorrect hence your answer came out wrong.
i think this might clear your doubt more then ask.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
