Batman4t
- 5
- 0
[SOLVED] velocity of a spring
https://wug-s.physics.uiuc.edu/cgi/courses/shell/common/showme.pl?cc/IAState/phys221/spring/homework/05/block_spring_nofriction/4.gif
A spring is stretched a distance of Dx = 40.0 cm beyond its relaxed length. Attached to the end of the spring is an block of mass m = 8.00 kg, which rests on a horizontal frictionless surface. A force of magnitude 40.0 N is required to hold the block at this position. The force is then removed.
When the spring again returns to its unstretched length, what is the speed of the attached object?
http://wug.physics.uiuc.edu/cc/IAState/Phys221/spring08/course%20info/FS.pdf
change in X=.4m
mass=8kg
F=k*dx
calculated k=100N/m
w=f*dl
work=.5mv^2
v=?
projected v=2m/s
How come 2m/s is not working for my speed did I make an error?
change in X=.4m
mass=8kg
F=k*dx
calculated k=100N/m
w=f*dl
work=.5mv^2
v=?
projected v=2m/s
