Velocity out of the Lorentz factor
The discussion focuses on deriving velocity from the Lorentz factor in the context of special relativity. The user seeks to understand how to extract velocity from the energy equation E=(γmv)c + mc² and the relationship between velocity and the Lorentz factor. The correct expression for velocity is derived as v = pc² / √((pc)² + (mc²)²). The conclusion emphasizes that in the coordinate system K', two events can occur simultaneously when the observer moves at the speed of light, reinforcing the concept of lightlike intervals.
  • Understanding of the Lorentz factor (γ) in special relativity
  • Familiarity with relativistic energy equations
  • Knowledge of lightlike intervals and their significance
  • Basic concepts of coordinate transformations in physics
  • Study the derivation of the Lorentz factor (γ) in detail
  • Learn about the implications of lightlike intervals in special relativity
  • Explore the relationship between momentum (p) and energy (E) in relativistic contexts
  • Investigate coordinate transformations and their applications in different inertial frames
Physics students, educators, and anyone interested in understanding the principles of special relativity and the mathematical relationships involving velocity and the Lorentz factor.
Aureum
System K:
x=a t=2a/c
x'=2a t'=3a/c
I need to figure out in what frame K' will these events appear to occur at the same time?
I know the answer is c/2 in the -x direction but finding I'm having a hard time finding the velocity.
I really confused on how to get the velocity out from Lorentz factor. That way I can solve for V. It's not just with this problem but often I find myself with an expression equaling velocity times the Lorentz factor.
When I try derive relativistic velocity from the relativistic energy equation
E=(ymvc)+(mc^2)
E=mc(yv+mc)
E/(mc)=yv+mc
(E/(mc))-mc=yv
How do I get the velocity out of the Lorentz factor so from the energy expression I can derive velocity?
E^2=(pc)^2+(mc^2)^2
to
v=pc^2/(√((pc)^2+(mc^2)^2))
Mathematics news on Phys.org
So in system K you have two events x1=(a,2a/c) and x2=(2a,3a/c)
The difference is (a,a/c) with magnitude sqrt(a^2-c^2*a^2/c^2) = 0, meaning the interval is lightlike.
In a new coordinate system K' the events shall occur at x1'=(0,0) and x2'=(a',0). (I picked the zeroes arbitrarily). The events obviously occur at the same time in that system since both time coordinates are the same. Since the interval must be unchanged regardless of the coordinate change, a'^2 = 0, i.e. a' must be zero.
Thus in the coordinate system K' the events occur at the same place and time. From Ks point of view, K' travels a distance a in a time a/c and is moving at speed c.
Intuitively, this makes sense. Suppose event 1 is a someone turning on a flashlight and event 2 is the light hitting a screen. For someone moving along with the beam of light the events are basically coincident in space and time.
Does that help?
If you have yv = v/sqrt(1-v^2/c^2) = 1/sqrt(1/v^2 - 1/c^2) then simply compute v = 1/sqrt(1/(yv)^2 + 1/c^2) = cyv/sqrt(c^2 + (yv)^2) to extract the velocity
Ya, that helps a lot thanks. I don't know what I was thinking earlier.
  • · Replies 19 ·
  • · Replies 16 ·
  • · Replies 17 ·
  • · Replies 55 ·
