drkidd22
- 59
- 0
You are not determining moments and the signs of the moments correctly. The moment of a force (or force component) is the the product of that force times the perpendicular distance from its line of action to the pivot point. Watch plus and minus signs.drkidd22 said:Homework Statement
attached .pdf file
M = Fd
See attached pdf please
I would like for someone to verify my answer, thanks
Yes, the moment from F1 about A is 80 in-lb ccw. Now move on to F2 and F3.drkidd22 said:So let's take F1. Wouldn't F1 be 10lb * 8in = +80 lb*in CCW?
Don't confuse force with moment. F3 is 10 lbs, so the moment of F3 about A is your correct answer of 100 in-lb.drkidd22 said:F2x = 10Sin60 = 8.66lb-in cw (which will be negative)
F2y = 10Cos60 = 5lb-in cw (which will be negative)
F3x = 10lb * 10in = 100lb-in ccw
Sorry, you had it correct, using the x-axis as the horiziontal axis, F2x is F2 cos 30, or F2 sin 60, same thing, and F2y is F2 sin 30, or F2 cos 60, same thing. Now what is the moment about A from F2x? What is the moment about A from F2y?drkidd22 said:I see what you mean for F2.
What I really solved for was:
F2x = 8.66lb
F2y = 5lb
but I don't understand about having the components reversed
Let's start with F2y. The moment of F2y about A is 5(12) = 60 in-lb. Clockwise or ccw? Plus or minus?drkidd22 said:F2x = 8.66lb * 12in = 103.92 in-lb
F2y = 5.00lb * 12in = 60.000 in-lb
