How Does Adding a Mass Impact Vibration Amplitude in an Undamped System?
  • Thread starter Thread starter jasonbot
    Vibration
The discussion focuses on calculating the changed displacement amplitude (X1') of an air compressor mounted on a spring system when an additional mass is introduced. The original mass (m1) is 150 kg with a spring stiffness (k1) of 3000 N/m, resulting in a measured displacement amplitude (X1) of 0.0002 m at an operating speed of 1800 r/min. After incorporating an undamped isolation system with mass (m2) of 12 kg and a natural frequency (w2) of 105 rad/s, the recalculated displacement amplitude (X1') is determined to be -0.000109 m. The calculations utilize the equation for vibration absorbers and static deflection to derive the final result.
  • Understanding of vibration absorber principles
  • Knowledge of dynamic systems and natural frequency calculations
  • Familiarity with spring stiffness and mass relationships
  • Proficiency in basic physics equations related to motion and forces
  • Study the principles of vibration absorbers in mechanical systems
  • Learn about static and dynamic deflection calculations in spring systems
  • Explore the effects of mass addition on system dynamics
  • Investigate advanced topics in undamped and damped vibration systems
Mechanical engineers, students studying dynamics, and professionals involved in vibration analysis and isolation system design will benefit from this discussion.
jasonbot
An air compressor of mass m1 = 150 kg is mounted on a spring of stiffness k1= 3000 N/m. The measured
displacement amplitude X1 = 0.0002 m at the operating speed of N = 1800 r/min. If an undamped isolation
system with mass m2=12 kg and a natural frequency w2 = 105 rad/s is fixed to the compressor, calculate the
changed displacement amplitude X1 for the overall system
As far as I understand this is the relevant equation: X1/delta_st=(1-(omega/omega2)^2)/((1+k2/k1-(omega/omega_1)^2)(1-(omega/omega_2)^2)-k2/k1)
As far as I understand its a vibration absorber problem.
omega=1800*(2π/60)=188,5rad/s
omega1=(k1/m1)^.5=4.47
k2=omega_2^2*m2=105^2*12=132300N/m
X1/delta_st=-5,836x10^-4
delta_st=-0,342m
I don't think that's right :|
It is a dynamic absorber problem. While I have not gone through your arithmetic, I see that delta_st is static deflection which is how much the weight of the compressor deflects the spring under static conditions.
You should be solving for X1. Here is your equation: X1/delta_st=-5,836x10^-4
Solve it for X1 by plugging in delta_st.
That makes sense actually.
So assuming that I go
delta_st=F0/k=(150+12)*9.81/3000=0.52974
X1=delta_st*-5,836x10^-4=-0.000309
so then I'm assuming the changed displacement amplitude will be the difference between measured and X1 from calculations.
so X1'=-0.000309+0.0002=-0.000109mOh and thanks! <--- Sorry I forgot to add that :|
That looks good to me. I went through your arithmetic...
