I Viewing Planets or stars from a high altitude
During the day, planets and stars are not visible from Earth due to sunlight scattering, and this remains true at lower altitudes in space. As altitude increases, visibility improves, but bright objects like Venus may still be difficult to see due to glare from the sunlit Earth. Astronauts on the ISS can see stars, but only the brightest ones are visible against the bright background of the Earth. Photographs taken in daylight from the ISS often lack stars because of the significant difference in luminosity between the Earth and celestial objects. Overall, while visibility improves with altitude, the brightness of the Earth limits star visibility during the day.
Anand Sivaram
TL;DR Summary
Viewing Planets or stars at high altitude
We can not see planets or stars during the day time because of the scattering of the sunlight. But, in space, all planets and stars would be visible. Consider the situation that a rocket is going to space during the day time. At what altitude these stars or planets would become visible? On the contrary, consider an astronaut coming back from the ISS to the Earth during day time. Until what altitude he could see bright stars like Sirius or planet Venus?
You can if you know where to look
I have seen Venus many times during the day
On the daylight side of the Earth, they won't be seen (except maybe Venus) for the same reason as on the ground ... the sun glare
Maybe you have not noticed the lack of stars in photos from the ISS and other spacecraft when in the daylight ... ?
Because you started with a flawed assumption, you need to reconsider your first statement
The Earth is very bright and will swamp dim images of stars and most planets unless the camera is mounted somewhere (outside, preferably) where there is no significant scattered light from a sunlit Earth.
The 'sky' gets progressively darker and darker as you go up and looks black from the ISS orbital height. Stars should look much the same as they do on a clear night on Earth. But if you try to take a photograph of the night sky with similar exposures to daylight Earth scenes, you won't see much. It's down to the massive differences in luminosity of objects in shot.
Anand Sivaram said:
I was under an impression that the Astronauts could see any star or planet from the ISS during their day time.
Very likely but I doubt that any but the brightest stars could be seen when they lie near the bright Earth. Our eyes are a lot better than cameras until we start to get cataracts - flare is a real s*d for us oldies. (We lack the right stuff I think.)
Likes Anand Sivaram
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
