Gravitational Collapse of Protostars: When Does Fusion Begin?
A protostar initiates gravitational collapse when its gravitational potential energy exceeds twice its thermal energy, requiring it to be cool and dense enough. As the collapse occurs, half of the gravitational potential energy converts to heat, while the other half radiates away. For fusion to commence, the protostar must reach a core temperature of approximately 11 million K, sufficient for deuterium burning and lithium destruction. The virial theorem indicates that the system's kinetic and potential energies are related, allowing predictions about the star's size based on its average temperature, mass, and density. Understanding these dynamics is crucial for identifying when nuclear fusion begins in protostars.
StephenPrivitera
A protostar will begin gravitational collapse only if the total gravitational potential energy exceeds twice the thermal energy. In other words, a gas has to be sufficiently cool and sufficiently dense to collapse. Also, as the protostar collapses about half of the gravitational PE is converted into heat, and about half is radiated into space. So suppose we have a protostar cloud with a thermal energy of T. If it is to collapse its gravitational PE should be >2T, say 3T. After some time, the protostar loses 2T in gravitational energy so that its gravitational potential energy is T. But half of the lost energy is now in heat, so the total thermal energy is now 2T. Will this protostar stop collapsing? How much must it collape before nuclear fusion begins?
Astronomy news on Phys.org
The easy answer is "until the core is hot and dense enough". Are you looking for something specific, e.g. how hot? how dense? or perhaps "it first begins to burn its deuterium, and destroy what little lithium it has, when [answer goes here]"
If the motions are not random/isotropic, the virial theorem still applies, but its form changes a bit. Similarly, since our system is made up of many objects, we can gain some insight by seeing how the orbital velocities vary with radius from the center outward.
For example, in a spiral galaxy, the dominant motion of the stars in the disk is circular rotation in the plane of the disk. The variation in the orbital velocities with radius V(r) is called the rotation curve.
Suppose you have a finite collection of point particles interacting gravitationally via good old Newtonian mechanics. And suppose that:
1. The time averages of the total kinetic energy and the total potential energy are well-defined.
2. The positions and velocities of the particles are bounded for all time.
Then we have:
<T> = -<V>/2
where <T> is the time average of the total kinetic energy, and <V> is the time average of the total potential energy.
I always found this to be a bit magical. It seems surprising at first that such a simple law could hold so generally. But in fact, it's just a special case of something called the "virial theorem", which also applies to forces other than gravity, and impacts everything from astronomy to the theory of gases.
For example, out in space, very often a bunch of particles will collapse to form a gravitationally bound system. If the system is roughly in equilibrium so the time averages of kinetic and potential energy are close to their current values, the virial theorem implies that T = -(1/2) V. we know that <T> = -<V>/2. This is a terrific thing, because it let's you find the masses of bound systems. In fact, it's really the reason we think that dark matter exists.
To be specific, suppose you measure the speeds of a bunch of visible objects in your system, and infer T. Then the virial theorem tells you V. If you find out that the potential well is deeper than what you'd get by adding up the contributions from the masses of everything you see, you know there's dark matter. People do this for spiral galaxies, elliptical galaxies, and galaxy clusters, getting strong evidence for dark matter in all cases, I guess.
Yes, I suppose this is exactly what I'm looking for. What measurements imply that nuclear fusion is occurring? Mass? density? Temperature?
Does this mean that a protostar which has the initial property T < V/2 will collapse until it reaches equilibrium at T = V/2? Suppose we know the average temperature, mass and density of a protostar. Can we predict what size star will result from the collapse by finding when T = V/2?
Temperature, and the EM spectra (same measurement). Sub-stellar masses radiate heavily in IR and radio, but you won't get x-ray, gamma ray or much UV unless the core temperatures reach ~11 million K to start fusion.
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
Asteroid, Data - 1.2% risk of an impact on December 22, 2032. The estimated diameter is 55 m and an impact would likely release an energy of 8 megatons of TNT equivalent, although these numbers have a large uncertainty - it could also be 1 or 100 megatons. Currently the object has level 3 on the Torino scale, the second-highest ever (after Apophis) and only the third object to exceed level 1. Most likely it will miss, and if it hits then most likely it'll hit an ocean and be harmless, but...
