Viscous Hydrodynamic Forces on Fixed Offshore Platforms
Viscous hydrodynamic forces, including nonlinear components, are indeed influenced by wave action and ocean currents acting on fixed offshore platforms. These forces arise primarily from environmental interactions, particularly water and wind action. The complexity of these forces necessitates thorough research to understand their implications fully. The discussion hints at applications in marine platform or wind turbine construction. Understanding these hydrodynamic forces is crucial for the design and stability of offshore structures.
wssrwsmt
Are the viscous hydrodynamic forces and the nonlinear viscous hydrodynamic forces applied on offshore platform in the ocean? The platform is fixed.
Just to expand on your question, there would be wave action and ocean currents acting upon the platform.
Thank you! So,wave action and ocean currents acting upon the platform produce the viscous hydrodynamic forces and the nonlinear viscous hydrodynamic forces?
Are you building a marine platform? Or a wind turbine out in the ocean?
Environmental forces on a platform would be that resulting from mainly water and wind action.
I am not sure how far of an answer you want with this, as it is a very complicated subject, as you would likely find out by searching on the web for viscous hydrodynamic forces on offshore platforms, or something similar.
Thanks for your answer!
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
