Voltage Difference Along a Path
The discussion focuses on calculating the voltage difference along a specified path using the electric field E. The user successfully integrates the electric field from point A to point P, addressing a division by zero issue by simplifying the expression for the integral. They confirm that the integral evaluates to 4 volts, consistent with the answer key. The conversation emphasizes the importance of correctly setting up the line equations for piecewise segments and resolving potential mathematical pitfalls. The user expresses confidence in their solution after receiving clarification on the simplification process.
Jake 7174
Given the electric field E = (2x−y2)ax + (3z−2xy)ay + 3yaz, and the piecewise linear path joining the points A(−2,1,−1), P(2,1,−1), Q(2,3,−1) and B(2,3,1), find −∫E⋅dl from A to P − ∫E⋅dl from P to Q − ∫E⋅dl from Q to B along the straight line segments.
−∫E⋅dl
(x - x1) / (x1 - x2 ) = (y - y1) / (y1 - y2 ) =(z - z1) / (z1 - z2 )
I have solved this problem going direct from point a to b by using the above equation and found that the answer is 8 v. This is confirmed by the answer key. Here is my problem, when I set up the line equation to go from point A to P I get the following;
(x + 2) / (-2 - 2) = (y - 1) / (1 - 1) = (z + 1) / (-1 + 1)
or, (x + 2) / -4 = (y - 1) / 0 = (z + 1) / 0
I am ultimatley going to solve for y and z in terms of x to express my integral in terms of just x and I know how to get rid of the pesky dy and dz as well but I need the line equation to not blow up on me.
How do I resolve the division by 0? I know that the VAQ = 4 v from the solution but I am not sure what to do about the line equation.
I have an exam on Monday and I am certain a question like this will appear.
Jake 7174 said:
Here is my problem, when I set up the line equation to go from point A to Q
Did you mean to write A to P?
The division by 0 comes from the special nature of the path from A to P. For that path, how would you simplify the expression
##\vec{E}\cdot d\vec{l} = E_xdl_x+E_ydl_y+E_zdl_z##?
TSny said:
Did you mean to write A to P?The division by 0 comes from the special nature of the path from A to P. For that path, how would you simplify the expression
I did mean to write A to P. I fixed it.
if y = z then dly = dlz = 0
so the expression simplifies to ##\vec{E}\cdot d\vec{l} = E_xdl_x##
If this is the case then I have
-∫ (2x - y^2) dx from x= -2 to 2 but Y =1
so, -∫ (2x - 1^2) dx = 4
This is the result I am looking for. I want to be sure I didnt luck into it and that I simplified it correctly as you suggested.
That looks very good.
Likes Jake 7174
Awesome, Thanks for your help
