Solving Voltage Drop Problem on Robotics Project
The discussion focuses on addressing a voltage drop issue in a robotics project caused by a 4.8V NIMH battery under load, which momentarily drops to 4.5V, restarting the embedded computer. Suggestions include adding a capacitor to the power supply, using a Schottky diode to prevent discharge into the motors, and implementing soft-start techniques for the motors to reduce sudden current draw. The importance of checking the processor's voltage operating range is emphasized, as many modern processors can handle a wider range than 5V. Additionally, the potential role of a reset chip that triggers a restart when voltage dips is noted, with recommendations for selecting an appropriate reset chip voltage. The user ultimately resolves the issue by switching to a 7.4V lithium polymer battery with a 5V regulator.
robotnut
22 Dec 2009 21:16 Voltage drop question
Hi All;
Total noob, first post:smile:
I'm working on a small robotics project. I have an embedded computer (5V) and 2 motors with a controller. It's all powered from a 4.8V NIMH battery.
The problem I'm having;
As the battery gets somewhat tired and I load the motors for starting or climbing a steep obstacle, the voltage drops a little from 5V to about 4.5 momentarily but it's just enough to restart the computer.
What I'm thinking of to solve this problem is adding a capacitor to the power cable of the computer. Would that help the problem? Like I said the drop only happens for a fraction of a second.
I know I could use a bigger battery but I have a room issue already as it is.
Thanx in advance.
You would need to give the currents of the motors and the computer.
If you just put a capacitor across the power supply, it would discharge into the motors when they turned on. You would get some benefit if the capacitor was large enough, though.
If you could operate the computer with 4.65 volts, this diagram shows a way that might help.
Using a Schottky diode, you could charge a capacitor which would then discharge only into the computer and not into the motors. Schottky dides have a drop of 150 mV (0.15 volts), so the 4.8 volts from the battery would drop to about 4.65 volts, but it would hold this voltage for short periods if the battery voltage dropped.
Could you modify the software so that the motors are always soft-started (progressively, not suddenly). Alternatively, try putting low-value resistances in series with the motors. Clearly if these are too big the motors will no longer work, but it might be worth trying.
I don't know what processor your using, but most modern ones have a large operating range (ie 3V - 5.5V). I'd check the part number on you processor and look up it's data sheet. Most likely, the operating voltage range will be listed in the first two pages (under features).
Most likely, your drop out is caused by an overly protective reset chip. These little three pin chips measure the voltage and reset the processor when it dips. The beauty part is that for a given reset part number, the there are any number of voltages that are available - most from Digi Key.
. Best Luck, keep me updated,
. - Mike
I = C dV/dT, and dV in your case is 0.5v. Plug in your values to calc. your min. cap. size.
For 1 A, 1 second and a max 0.2v difference you'd need 5 F.
Thanx for all the help, I did a cheap fix. Went with a 2 cell 7.4V 1000MAH lithium polymer battery with a 5V voltage regulator...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
