Voltage of a point in varying permittivity medium problem
The discussion revolves around calculating the voltage at a point in a medium with varying permittivity due to a point charge located at the origin. The relative permittivity is defined as a function of distance from the charge, specifically \(\varepsilon_r = a / r\), where \(a\) is a constant. Participants are attempting to derive the expression for voltage around the charge.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss using Gauss's Law in different forms to approach the problem. There are attempts to integrate the electric field to find the voltage, with some questioning the limits of integration and the assumptions made about voltage at infinity.
There appears to be ongoing exploration of the integration process and the implications of setting voltage at infinity to zero. Some participants suggest that the integration limits may need reconsideration, while others note that the behavior of voltage should decrease with increasing distance from the charge if it is positive. Multiple interpretations of the integration process and its implications are being discussed.
Participants are navigating the complexities of integrating in a medium with non-constant permittivity, and there is mention of potential discrepancies in the expected results based on assumptions made during integration.
null void
- A point charge is placed at the origin of the medium.
- The relative permittivity of the medium, [itex]\varepsilon_r = a / r[/itex], a is a constant, r is the radius from origin to any point around the charge.
- Objective of this question is to find the expression for voltage.at any point around Q
[itex]\vec E = \frac{Q}{4\pi \varepsilon_0 \varepsilon_r r^2} \vec r[/itex]
[itex]= \frac{Q}{4\pi \varepsilon_0 (\frac{a}{r}) r^2} \vec r[/itex]
[itex]= \frac{Q}{4\pi \varepsilon_0 a r }\vec r[/itex]
[itex]V = - \int_\infty^r{\vec E \cdot d \vec l}[/itex]
[itex]= - \int_\infty^r{ \frac{Q}{4\pi \varepsilon_0 a r } dr}[/itex]
[itex]= - \frac{Q}{4\pi \varepsilon_0 a}[ln r - ln \infty][/itex]
[itex]= \frac{Q}{4\pi \varepsilon_0 a}[\ln \frac{\infty}{r}][/itex]
In the integration i use [itex]\infty[/itex] as lower boundary to assume the infinity is at 0 voltage.
But the expression seems to be wrong, anyone know where did I messed up?
Try to work by Gauss's Law in differential mode.
Sorry, I don't quite get you. I have searched around about that differential form, I am not sure what should i find with it.
[itex]Q = \int\int D \cdot ds = \int\int\int \rho_v dv[/itex]
The Q is given in the question as a constant, D can be derived out by Coulomb's law.
The answer for the question is
[itex]V = \frac{Q}{4\pi \epsilon_0 a}\ln{r}[/itex]
it seems as if the integration(in my 1st post) takes the lower boundary at r=1 and upper boundary at r = r
I think than there is a trick on integration.
null void said:
In the integration i use ∞\infty as lower boundary to assume the infinity is at 0 voltage.
Integration limits driven by ##dl## incrase. So I think the correct integral is:
$$ V = -\int_r^\infty \mathbf{E}\cdot{d\mathbf{l}} \Rightarrow V = \frac{Q}{4\pi\epsilon_0a}\,\ln{r} - V_\infty $$
and now you can take ##V_\infty=0##.
Your work looks correct. As you've discovered, you run into a problem if you try to set the potential equal to zero at infinity. The same thing happens for the potential due to an infinitely long, uniformly charged line of charge.
So, you can just pick an arbitrary point for V = 0. As you stated in post #3, it looks like the given answer takes V = 0 at r = 1. However, the overall sign is incorrect in their answer. V should decrease as r increases, if Q is positive.
That is correct for constant ##\epsilon##. The same calculation in this case produce the known result.
Behaviour is the same as a charge ##Q## leaves on a 2D world.
We haver [itex]\vec E = \frac{Q}{4\pi \varepsilon_0 \varepsilon_r r^2} \hat r[/itex] which is valid for any "Class A" dielectric, even when ##\varepsilon_r## is not constant.
If Q is positive you can see that ##\vec E## will be radially outward from Q as long as ##\varepsilon_r## is positive (as usual). In this case, V must decrease as r increases.
  • · Replies 19 ·
9K
