Volume of Frustum Pyramid: 19800.44 ft^3Calculate Volume of Frustum Pyramid
  • Thread starter Thread starter blimkie.k
    Pyramid
The discussion focuses on calculating the volume of a frustum pyramid with a square base and a larger six-sided top. The user initially applied a formula from Wikipedia but later identified a mistake in their calculations, leading to a revised volume of 950,181.33 cubic inches. They also explored the Heronian mean as a method for volume calculation, which yielded a significantly smaller volume. The conversation highlights the importance of using the correct formula and understanding the geometric properties involved. Accurate calculations are crucial for determining the volume of complex shapes like frustum pyramids.
blimkie.k
I had a similar question in the "engineering systems and design" category but didn't get any replies so hear is the simple version involving only the math.
Basically I just need to see if I am using the correct formula to the calculate the volume of a frustum pyramid. However the bottom of the pyramid is a 24"x24" square and the top would be a place which much much larger 6 sided shape, with all sides different lengths. I just need to know if this formula will work for a frustum pyramid with a square for one plane and a 6 sided shape for the other plane and a depth of 4" Here is my math.
This is not a school related question.
The formula was found on wikipedias entry for a frustum pyramid
Height = 4 inches Area 1 = 713392”
Area 2 = 756” (24”x24”)
Volume = (height *area1) – (height*area2)
= ( 4” * 713392”) -( 4” * 576”)
Volume = 2851264 inches cubed
Convert to feet cubed ( 1 ft^3 = 144 in^3
2851264 / 144 = 19800.44 feet cubed
Mathematics news on Phys.org
Ok i see, I want to use that one because in my case the apex has allready been sliced off so I'm not finding the difference between a full pyramid and one with a flat top.
There was a mistake up there in my math the volume should actually be 950181.33 and the i pasted the formula in from word so it didn't show my underline which was intended to show division but anyways.
Also what is the difference between this and the heronian mean.
http://en.wikipedia.org/wiki/Heronian_mean
Running the formula this way gives me an even smaller number almost 4 times smaller.
Wiki: Heronian mean said:
The volume is equal to the product of the height of the frustum and the Heronian mean of the areas of the opposing parallel faces.
a_1=24^2, a_2=713392, h=4
V=\frac{h}{3}\left(A_1+A_2+\sqrt{A_1A_2}\right)
V\approx978985.345
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
