Calculating Volume of Solid Rotated about Y-axis from Bounded Curves
mxthuy95
Consider the region bounded by the curves y= lnx and y=( x-3)^2
Find the volume of the solid obtained by rotating the region about the y-axis
For this I solve for the x so i got x= e^y and x= (y)^(1/2) +3
and for volume equation i got :
1.47
∫ ((y)^(1/2) +3)^2 - (e^y)^2 = 12.481(pi). My answer is
different from the book. So can someone point out wat i done wrong and help me to get the right answer
Thank you
I cannot see what you did wrong because you did not show your working - you went right from the integral to the final numerical value ... and the integration you show does not look like the one for volume of rotation.
So I cannot tell what you were doing.
I suspect you need to sketch the two curves in the x-y plane and shade in the region bounded by them. The curve ##y=(x-3)^2## intersects the curve ##x=e^y## in two places. ##x=\sqrt{y}+3## only gives you part of the curve you need.
You appear to be using the 'washer' method, i.e. a stack of elemental discs. This isn't going to work as a single range of integration because there's a sudden change of behaviour at the lower solution of ln(x) = (x-3)2. (Try drawing the region, as Simon advises.) I suggest the cylinder method.
Hi
Is this the right set up for the shell method
radius = x and height = lnx- (x-3)^2 so i get
A= 2(pi)x((x)(lnx-(x-3)^2) = 2(pi)(xlnx - (x)(x-3)^2 )so volume =
4.170
2(pi) ∫ (xlnx - (x)(x-3)^2
2.127
Thanks
mxthuy95 said:
4.170
2.127
Yes, except that I get slightly different bounds: 2.130, 4.198.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
