How Can the Midpoint Rule Estimate the Volume of a Liver from CAT Scan Data?
  • Thread starter Thread starter tictactony
    Volume
tictactony
A CAT scan produces equally spaced cross-sectional views of a human organ that provide information about the organ otherwise obtained only by surgery. Suppose that a CAT scan of a human liver shows cross-sections spaced 1.5 cm apart. The liver is 15 cm long and the cross-sectional areas, in square centimeters, are 0, 19, 58, 79, 95, 105, 116, 128, 63, 40, and 0. Use the Midpoint Rule with n = 5 to estimate the volume V of the liver.
Not sure what I'm suppose to use, disk method? V = \int\pi r^{2}
I'm not sure if I'm supposed to treat this like I would a normal riemann sum using the midpoint rule because the question is asking for a volume and I'm given surface area. The way I see this problem I feel like I have to add up all the surface areas because that's what you do when you find volume by integration. This wouldn't make sense though since I'm given the midpoint rule of n=5.
That is puzzling given that the data cover 10 intervals. It smells like a question that has been modified inconsistently.
n=5 requires 5 intervals, so 6 datapoints. Which 6 of the 11 to choose? I would answer using n=10.
You have a set of readings at boundaries of given intervals. If the readings have dimension X and the intervals have dimension Y then the sum of the pairwise products has dimension XY. In this case, X=L2, Y=L, so XY=L3.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
