How does this relate to the size and mass of gas giants like Kepler 7b?
In summary, the size and mass of gas giants like Kepler 7b are directly related to their formation and composition. These planets are typically larger and more massive than Earth due to their formation in regions of the solar system with higher levels of gas and dust. Additionally, they have a lower density, making them less dense than Earth and enabling them to retain large amounts of gas. The mass of gas giants is also influenced by the amount of hydrogen and helium present, as these gases are responsible for the majority of their mass. Overall, the size and mass of gas giants are important factors in understanding their formation and structure.
Ian J.
Or, just how big can a gas giant get?
I read this article recently:
http://www.bbc.co.uk/news/science-environment-24348024
In it, Kepler 7b's clouds are 'directly' mapped for the first time. The planet itself is said to have an overall mass roughly that of polystyrene. Bearing in mind that for a long time Jupiter has been posited as roughly how voluminous a planet can get before it gains mass rather than volume if it gets any more massive, is this world proving to be the exception to that 'rule', and what does it say about just how much more voluminous a world could potentially get? Will we discover much larger, more voluminous worlds than Kepler 7b?
Astronomy news on Phys.org
Kepler 7b is a hot Jupiter. It's naturally going to be more voluminous than would be a cold gas giant of equal mass.
True, but my question was just how big could a gas giant get. I suppose I need to add that the local conditions might need to be defined too, if they can have a significant effect.
The minimum mass for deuterium fusion is about 13 Jupiter masses. This limits the maximum mass of an extrasolar planet before it is considered a brown dwarf. At around 75 Jupiter masses, a brown dwarf is capable of hydrogen fusion. It is then considered a red dwarf star.
That's big by mass, not big by volume which is what the thread is about.
Adding more mass to Jupiter would not increase its volume. This is because the added mass would increase the pressure inside the planet and the overall effect would be that the planet contracts. However, we're missing a key component here if you want to compare different planets. Temperature. A planet like Kepler 7b is MUCH hotter than Jupiter is. Remember that Jupiter is almost entirely hydrogen and helium. Gasses. A volume of gas expands when heated up. So if we heated Jupiter up to Kepler 7b's temperature it would grow to a larger volume.
So temperature could be considered the local condition affecting Kepler-7b. How much volume expansion of the gasses can the temperature cause? What is likely to be the maximum volume of gas giant before the temperature can't push out the gasses any more?
I'm also presuming, with such temperatures, that such low density, high volume worlds are likely to be short lived due to whatever fuels the heat burning up?
No idea.
What do you mean? What fuels and why would the planet disappear?
I didn't mean 'disappear'. I suppose 'short lived' was a poor choice of words on my part.
I mean that the heat that is keeping the gases expanded, if coming from inside the planet, must be being generated by something and I'm presuming it's an internal process rather than an external one coming from an orbited star. That heat would have to have a fuel, and that would eventually deplete to the point that the heat generated would no longer be enough to keep the gases expanded. At that point, the gases would cool and contract, meaning the planet would no longer be a low density voluminous one, and become more like Jupiter as a higher density, smaller volume gas giant.
The heat is actually coming mostly from the star. Hot Jupiters are so hot not because of some special processes of energy production in their interiors, but because they orbit their stars in very tight orbits. Like balloons of hot air heated by the fire of a burner, they swell up.
The largest exoplanets so far discovered, TrES-4b and WASP-12b are approximately 1.7 times the size(radius) of Jupiter, with something like 0.9 and 1.4 of its mass respectively. They orbit their stars at between 5 and 2% of the Earth-Sun distance.
Check this paper's(http://arxiv.org/pdf/1103.3078.pdf) data(tables 5 and 7) for more precise values. There's also some discussion of why these are anomalous(i.e., current models are inadequate), and references to other papers.
Likes 1 person
OK, that explains a lot, thanks! :)
One other consideration is density, which is the object's mass divided by the object's volume. If you increase the mass to ~13 Jupiter masses, but keep the radius the same as Jupiter, then the density of the planet would be about the same as gold (17.31 g/cm3).
Brown dwarfs, as Chronos mentioned, are formed when a planet reaches ~13 Jupiter masses and begins to fuse deuterium, but that also implies ~13 Jupiter radius in order to have the same (or in Jupiter's case, slightly higher) density as deuterium (1.11 g/cm3).
A planet could potentially be much bigger than 13 Jupiter radius, and still be ~13 Jupiter masses, in which case it would not be dense enough to fuse deuterium, and therefore not considered a brown dwarf. Brown dwarfs are determined by when they start fusing deuterium, not by their mass or radius.
A planet that is 43.4 times the mass and radius of Saturn, for example, would not have sufficient density to begin deuterium fusion. Even though that planet would be 13 Jupiter masses, its volume is considerable more than 13 times the volume of Jupiter, and therefore has a much lower density.
That's correct. Brown dwarfs are rather dense objects, and they get even more dense as they age and cool off, therefore shrinking. A rather old and very large brown dwarf can have a density of more than 200 g/cm3.
That's incorrect. You are forgetting about gravitational effects. Gases does not have one density. Compress a gas and the density increases. Compress a gas a lot and the density increases a lot. Compress it even more and it becomes a solid. Even solids are compressible given enough pressure. For example, the iron in the Earth's core has a density 1.66 times that of iron at the Earth's surface. The Earth's gravity field is rather puny compared to that of Jupiter, which in turn is smaller than that of a brown dwarf.
In addition to D H's post: don't mix volume and radius. Volume scales with the cubed radius, so 13 times the volume means just 2.35 times the radius.
There is no "minimal density" for fusion. Actually, the biggest and most luminous stars have a very low average density. It can be below the density our atmosphere (~1.3kg/m^3).
Brown dwarfs, especially older ones, are typically smaller than Jupiter. Young ones can be a tiny bit larger, but not much. Here's a nice plot from the scholarpedia article on brown dwarfs (http://www.scholarpedia.org/article/Brown_dwarfs):
The black triangle near the lower right: That's Jupiter. The other labeled objects are red dwarfs. The dashed red curve is a model of objects at an age of 400 million years. The solid black curve, an age of five billion years. The low point on the black curve corresponds to density of over 200 g/cm3.
I have no doubt that is the case.
Would not the gravitational effects be determined by the volume the mass is contained within? The less volume, the more the mass (gas in this case) is compressed.
Also, I did take into consideration the gravitational effects, which is why I concurred with Chronos that ~13 Jupiter masses is when the planet begins fusing deuterium and becomes a brown dwarf. If I did not take gravity into consideration then it would merely be a planet that is 13 times the mass of Jupiter, and not start fusing deuterium.
I was not aware of that.
As far as mass is concerned, you are quite correct. Although, it may be possible for planet with ~13 Jupiter masses, and significantly denser (much more than 13 times Jupiter's density) to begin deuterium fusion while being much smaller than 13 Jupiter volumes.
That's not the order of effects - gravity compresses stuff until there is an equilibrium between pressure gradient and gravitational forces.
Without gravity there would be no planets or stars at all.
How would that object be stable? It would just expand until it is a regular planet.
You are quite right, and I did notice my mistake in the last sentence of my post. Thanks for catching it.
That seems contradictory. In order for fusion to occur, would you not need a large amount of mass in a very small volume?
The core density is relatively high (and pressure and temperature are really high), the density in the outer regions (>99.99% of the volume) is low, giving a low average density.
Yes, I understand that. I did not mean to imply that gravity is determined by volume. Mass and density determine the gravitational effects, and that in turn determines the volume.
If there is insufficient mass, there will be no fusion, because gravity will not be able to compress the material sufficiently. However, if you could introduce more mass, then the effects of gravity increases, compressing the gas (reducing the volume) in the process, and thus increasing the density of the material.
Agreed.
A ~13 Jupiter mass planet with a density of 2.156 g/cm3 would have a radius (not volume, I am paying closer attention) only twice that of Jupiter. Why would that be unstable? I do not understand.
I was under the impression that density was calculated by dividing the mass of an object by its volume. While I do understand that it is merely a mean average density, I was not aware that density was also determined by the distance one was from the center of an object.
Could you please point me to someplace were I might find the equations for calculating this graduating density?
Thanks.
That's what happens at ~13 Jupiter masses.
Why do you think such an object would exist? It would have a volume similar to Jupiter, slowly fusioning deuterium.
It is not "determined" by that, but density can depend on the position in the object. For stars, the density is mainly a function of the radius and decreases with increasing radius.
This is given by the hydrostatic equilibrium.
FAQ: How does this relate to the size and mass of gas giants like Kepler 7b?
What is the difference between volume and mass?
Volume is the amount of space occupied by an object, while mass is the amount of matter in an object. In other words, volume measures the size of an object, while mass measures the amount of material it contains.
How does Kepler 7b's volume compare to its mass?
Kepler 7b is a gas giant exoplanet with a mass 4.58 times that of Jupiter and a volume 1.59 times that of Jupiter. This means that Kepler 7b has a lower density than Jupiter, as it is less compact despite having a greater mass.
Why is the study of volume and mass important in astronomy?
The study of volume and mass in astronomy helps us understand the composition and structure of celestial bodies. By comparing the volume and mass of different objects, we can learn about their density, which can provide clues about their formation and evolution.
How does the volume and mass of Kepler 7b affect its orbit?
The volume and mass of Kepler 7b play a crucial role in its orbit. The planet's large mass creates a strong gravitational pull, which affects the orbits of its moons and other nearby objects. The volume also affects the planet's density, which can impact its ability to retain an atmosphere and contribute to atmospheric dynamics.
How do scientists measure the volume and mass of exoplanets like Kepler 7b?
Scientists use a variety of methods to measure the volume and mass of exoplanets, including transit photometry, radial velocity, and the transit timing variation method. These techniques involve observing the effects of a planet's gravitational pull and its size on the light of its host star. Additionally, space telescopes like Kepler and TESS provide valuable data on exoplanet size and mass through their observations of transits and radial velocity shifts.
