Water evaporation in semi-open system
The discussion revolves around the physics of water evaporation in a semi-open system, specifically focusing on a closed container with an opening at the bottom. Participants explore the effects of temperature, pressure, and vapor dynamics on the rate of evaporation and the conditions under which vapor escapes the container.
  • One participant questions how much pressure is needed for water vapor to escape through the bottom opening of the container.
  • Another participant states that the equilibrium vapor pressure of water at 80°C is 0.46 atm and suggests that the total pressure in the vapor space remains at 1 atm due to the open system.
  • There is a discussion about the implications of the vapor pressure and the composition of gases in the container, with some participants noting that the partial pressure of water vapor can only reach 0.46 atm while the rest must be air.
  • Concerns are raised about the apparent violation of the 0th Law of Thermodynamics regarding temperature differences between the water and the container.
  • Some participants argue that vapor can flow out of the container as long as the partial pressure of water vapor inside is higher than that outside, regardless of the vapor temperature.
  • A later post introduces a related scenario involving a different liquid and asks about calculating evaporation rates in an open system with reduced surrounding pressure.
Participants express differing views on the conditions necessary for vapor to escape the container, particularly regarding the role of temperature and pressure. There is no consensus on the exact mechanics of the evaporation process or the implications of the temperature differences observed.
Participants note that the discussion involves assumptions about the behavior of gases and the conditions under which evaporation occurs, including the effects of temperature and pressure on vapor dynamics. The complexity of mass transfer and heat transfer processes is acknowledged but remains unresolved.
This discussion may be useful for individuals interested in thermodynamics, fluid dynamics, and the principles of evaporation in varying pressure conditions, particularly in experimental or applied contexts.
TheFistGuy
Hello guys!
I'am having trouble getting my head around the physics of evaporation in quite specific situation.
So i have a closed container with opening in the bottom (cross-section in picture below). Let's say that water has a constant temperature of 80°C and container has a temperature 90°C, therefore the water cannot condense on the inner edges of the container. Outside the container is air with sea-level pressure.
So water evaporates and since vapor is lighter than air and it rises up. As it builds up in the container it should create some pressure (right?). Then due to the pressure the vapor should start escaping through the bottom (right?). So the first question is how much pressure is needed for the vapor to escape through the bottom?
And since vapor pressure builds up, that should slow the rate of evaporation. Is there any way to calculate this?
I will appreciate any help or links to related problems. Thanks!
What is the equilibrium vapor pressure of water at 80 C? If the pressure in the room is 1 atm, what do you think the total pressure in the "vapor space" within the container above the liquid water is?
At 80 C vapor pressure is 0.46 atm.
Pressure in the "vapor space" space should still be 1atm since it's an open system.
What does that tell me?
That tells you that the most that the average partial pressure of the water vapor in the head space can be at any time is 0.46 atm. The rest of the gas has to be air.
If the pressure outside the partially enclosed space is 1 atm, (assuming the opening isn't extremely small), then the pressure inside is 1 atm. I am not sure how the water remains 10° cooler than the container it is in, could you explain that (apparent) violation of the 0th Law of Thermodynamics? (Two objects in contact at equilibrium will reach the same temperature). While pressure is one way, and often used, to characterize a gas's composition, it is better here to consider that the key question is about the mixing of the air water gas with the atmosphere - which will occur around the opening. In real world conditions, the air-water mix will cool and water will condense into fog droplets and fall (there will also be some water vapor diffusion - unless the air is at 100% rh)
So if I get this right, then the only way vapor starts flowing through the bottom opening into atmosphere is if the vapor temperature is at least 100 C, i.e., water boils ??
The container is being heated. Therefore water will be few degrees cooler that container.
No, they certainly were not telling you that. The gases act independent of each other: as long as the partial pressure of water vapor in your container is higher than the partial pressure of atmospheric water vapor, water vapor flows out.
So far we have established that the composition of the vapor in the overhead space involves a mole fraction of water vapor of ≤ 0.46 and a mole fraction of air of ≥0.54 (all at 1 atm.). In the air outside, the mole fraction of water vapor is much less than 0.46 and the mole fraction of air is close to 1. So there is a concentration difference between the gas outside and the gas in the overhead space. Therefore, there is a mass transfer driving force for water vapor to exit the head space. Part of this the mass transfer (probably not much because the higher temperature is on top) can be by convection, so most will likely occur by diffusion in the tube. Knowing the diffusion coefficient, Fick's law can be used to determine the mass flow rate of water vapor. There is also heat transfer occurring by conduction occurring simultaneously within the tube. All this can be modeled.
And should not that be when vapor temperature is atlest 100 C?
Edit: ok no. Water vapor pressure in atmosphere is 0.023 bar at 20 C
I have a related question but a bit different. Suppose I have a bottle of liquid (other than water - similar or low volatility). The bottle has a small opening (say 10 mm) on its top and wind blows over the top of the bottle. So, there will be pressure drop through the orifice or opening.
Is there any way to calculate for a given pressure drop what will be the evaporation rate?
Or let me rephrase the question -
Is there any method to determine rate of evaporation in a open system with surrounding pressure less than atmospheric (or maybe vaccum) ?
  • · Replies 30 ·
  • · Replies 40 ·
9K
  • · Replies 32 ·
