(Water Heater)Geyser Heating Cycle
  • Thread starter Thread starter roro36
    Cycle Heating
The discussion centers on the efficiency of turning a geyser on and off versus leaving it on continuously. The user has found that turning the geyser off during inactive periods saves money, but is conflicted about the best approach for heating water during peak usage times, like evening showers. They consider whether to keep the geyser on during high-demand hours or to heat water only when needed, balancing energy savings with convenience. The consensus suggests that longer periods of the geyser being off lead to greater energy savings. Ultimately, the choice hinges on individual usage patterns and preferences for hot water availability.
roro36
Ok, I know there is the argument about switching off/on a geyser versus the leaving it on all day argument, let's argue that for specific set of circumstance I have found out that the turn off method is saving me money. This choice now seems to have me in two minds. 1 is to keep the geyser on durning times of activity, such as from 7 till 10 at night when everyone showers. Or to turn it on when everyone is finished, assuming the water stays hot enough. Which will mean the you can heat only the amount of water used for each cycle?
Any thoughts?
The longer it is off, the more energy you will save.
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
