How Fast Does Ice Sublime to Vapor at Extremely Low Pressure and -40°C?
  • Thread starter Thread starter NSS
    Water
At -40°C and 0.5 psi, ice will sublime to vapor, but the rate will be very low without added heat. Even in a dry hydrogen environment, sublimation occurs due to the non-zero vapor pressure of ice at that temperature. The rate of sublimation is influenced by factors like the agitation of hydrogen, which can enhance mass transfer. While the surrounding atmosphere is primarily hydrogen, the driving force for evaporation is the difference between the vapor pressure of the ice and the hydrogen. Overall, sublimation will happen, but at a minimal rate under the specified conditions.
NSS
Say we have 2 liter of water ICE in a 2 liter soda bottle.
Assuming sea level air pressure is, 14.7 PSI
We lower the temperature of the atmosphere around the ice to -40C
And we lower the pressure to 0.5 psi (roughly 75,000 feet)
The air around the ice is pure dry no water vapor in it at all. It's container, (probably a 2 liter soda bottle) will be vented via a tube to a balloon, that is filled with Hydrogen.
assuming this environment, at what rate would the ice Sublime to water vapor?
And how many cuft or cubic meters of water vapor would it produce for "X" amount of time?
Thanks
Unless you add heat to the ice, I think the rate of sublimation will be very low, if not zero. At the conditions you specify, the ice will be happy to stay solid.
Low is a relative number.
How much do you think as a low number?
How about zero?
Even at -40 degrees, ice has a non-zero vapor pressure. If the air is bone dry, the ice will certainly evaporate into it. The rate at which this happens depends on a number of factors, but obviously will be very low. By the way, it's very unlikely that atmospheric air at 75000 ft will be bone dry.
But what the water is exposed to is bone dry, 100% Hydrogen only.
Well at least 100% Hydrogen only until the water starts to enter it, by the sublimation.
Well, yes. Hydrogen. But that wasn't really relevant to what I was saying. At the interface between the ice and the hydrogen, the partial pressure of the water is the equilibrium vapor pressure of ice at -40. The difference between this partial pressure and the partial pressure of water vapor in the bulk of the hydrogen phase (zero) provides the driving force for evaporation. The mass transfer occurs by water vapor diffusion through the hydrogen in the immediate vicinity of the interface. The more that the hydrogen is mixed/stirred/agitated, the thinner the diffusion boundary layer at the ice interface, and the higher the rate of mass transfer (evaporation).
True,
