Wave Equation, stuck on a partial calculation
Somefantastik
Hey everybody,
My professor started our PDE I class in Chapter six, so I am having a hard time with the really basic stuff to get the theory down.
One of my questions to answer is to verify a solution by using direct substitution.
u(x,t) \ = \ \frac{1}{2}\left[\phi(x+t) \ + \ \phi(x-t) \right] \ + \ \frac{1}{2} \int^{x+t}_{x-t}\Psi(s)ds
With initial conditions
u(x,t_{0}) = \phi(x) \ , \ \frac{\partial u}{\partial t} (x,t_{0}) = \Psi(x), \ and \ t_{0} = 0
satisfies \frac{\partial^{2}u}{\partial x^{2}} - \frac{\partial^{2}u}{\partial t^{2}} = 0
It was easy for me to plug and chug to show that u(x,t_{0}) = \phi(x) \ and \ \frac{\partial u}{\partial t} (x,t_{0}) = \Psi(x)
Clearly my next step is to find \frac{\partial^{2}u}{\partial x^{2}}
but that's the step on which I'm stuck. Can someone get me started? If someone can show me how to do the second partial w.r.t x, it would be a good exercise for me to figure out the second partial w.r.t t. I apply the chain rule and just get a bunch of garbage back, which means I'm messing it up somewhere.
Any input is appreciated.
You need "Leibniz' formula":
\frac{d}{dx}\int_{\alpha(x)}^{\beta(x)} \phi(x,t)dt= \frac{d\beta}{dx}\phi(x,\beta(x))- \frac{d\alpha}{dx}\phi(x,\alpha(x))+ \int_{\alpha(x)}^{\beta(x)} \frac{\partial \phi}{\partial x}dt
It's really just applying the chain rule correctly.
<br /> \frac{d}{dx}\int_{\alpha(x)}^{\beta(x)} \phi(x,t)dt= \frac{d\beta}{dx}\phi(x,\beta(x))- \frac{d\alpha}{dx}\phi(x,\alpha(x))+ \int_{\alpha(x)}^{\beta(x)} \frac{\partial \phi}{\partial x}dt<br />
I'm having trouble understanding this. It looks like the integrand you gave is a function of 2 variables, but the integrand I have is a function of one variable. I'm not sure what to do with that.
Also:
\frac{\partial}{\partial x} (\phi(x+t)) = ?
is it = \phi &#039;(x + t), \ or \ \phi_{x}(x+t) \ ?
In the notation of a function, how do I write that? I guess I'm having a notational brain fart.
I found this worked out in Walter Strauss's book, so I guess I don't need help anymore. Thanks for looking :)
In that case,
\frac{\partial\phi}{\partial x}= 0
and the formula becomes
Also:
Use the chain rule. If \phi&#039;(u) is the derivative of \phi as a function of the single variable u, then
\frac{\partial\phi(x+t)}{\partial x}= \phi&#039;(x+t)(1)= \phi&#039;(x+t)
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
