Is the Fabry-Perot Interference Dependent on Pulse Duration?
The discussion centers on the relationship between pulse duration and Fabry-Perot (FP) interference. It establishes that for effective interference within an FP interferometer, the incident pulse must overlap with its reflected counterparts, which is contingent on the pulse's temporal coherence. The participants confirm that a continuous wave (CW) analysis is valid only when the structure's dimensions are smaller than the temporal coherence length of the pulse. This highlights the importance of understanding both time and frequency domains in optical pulse behavior.
  • Understanding of Fabry-Perot interferometers and their operational principles.
  • Knowledge of temporal coherence and its implications in optical physics.
  • Familiarity with Fourier transforms in the context of signal processing.
  • Basic concepts of pulse duration and its effect on frequency components.
  • Research the principles of temporal coherence and its measurement techniques.
  • Study the mathematical foundations of Fourier transforms in optical systems.
  • Explore the design and applications of Fabry-Perot interferometers in various fields.
  • Investigate the effects of pulse duration on interference patterns in optical experiments.
Optical physicists, engineers working with interferometry, and researchers studying pulse dynamics in photonics will benefit from this discussion.
IcedCoffee
I get that a single (optical) pulse is a superposition of continuous frequency components of its spectrum, but I'm a bit confused how Fabry-Perot interference can be interpreted in time domain.
In a single-frequency explanation, the idea is that the incident wave goes through multiple reflections inside a simple FP interferometer consisting of two partially transparent mirror. At resonant frequencies those reflected waves will interfere constructively (or destructively) and get transmitted (or reflected) completely.
But in a broadband pulse, it seems like:
(1) Given a long enough FP cavity, each pulse won't interfere with each other as they are separated in time.
(2) If we consider the initial incident pulse, it will simply go though the FP cavity, losing some of its energy due to the two reflections. However, it will still retain frequency components that would have been completely reflected due to destructive interference in the single-frequency picture.
EDIT: Ok, I guess the multi-reflected pulses that follow this initial pulse will have time interval based on the FP cavity. This will remove the destructively-interfering frequency components when I take the Fourier transform of the total output signal... But if I'm doing an experiment in which I record only the initial pulse and disregard the multi-reflected pulses, the FP interferometer will not remove those frequencies, right? And certainly, energy in that frequency component gets transferred through the FP interferometer?
So the output of the system is not a superposition of the single-frequency outputs? Or is there something wrong with my conjectures (1) & (2)?
Thank you all in advance :)
Science news on Phys.org
You are right. Any real-world pulse is of finite time-duration, and the smaller this time is the broader the pulse is in the frequency domain. A pulse can only interfere in a Fabry Perot interferometer if the pulse and the reflected pulse overlap, i.e., if the pulse is broad enough in the time (i.e., narrow enough in the frequency) domain. That's also known as (temporal) coherence. See the nice Wikipedia article (particularly the section about temporal coherence):
https://en.wikipedia.org/wiki/Coherence_(physics)
Thank you for your reply! The Wikipedia page was really helpful too.
So can I say that CW analysis of a structure is only valid when the structure's dimension is smaller than the temporal coherence length of the pulse?
  • · Replies 29 ·
  • · Replies 29 ·
  • · Replies 27 ·
  • · Replies 17 ·
