Underwater Currents & Wave Speed - Philipp's Question
  • Thread starter Thread starter philipp2020
    Water Waves
In an underwater current of 10 m/s, waves generated by a stationary device will travel faster than in still water due to the additive effect of the current. However, if the device moves at 5 m/s while generating waves, the speed of the waves relative to the medium remains unchanged; instead, the wavelength will vary due to the Doppler effect based on the device's movement. The propagation speed of waves is determined solely by the medium's physical properties, although in dispersive mediums, wave speed can depend on wavelength. The discussion also touches on advection, where the bulk motion of the fluid can influence wave transport in certain conditions. Overall, the interaction between wave speed and current dynamics is complex and influenced by both the medium and the motion of the wave source.
philipp2020
Hi
Ive got a short question:
Lets say there is an underwater current with 10 m/s going right.
Then I have a device which creates waves standing still in this current at one point. Are the waves sent out by this device faster in this current than if there wouldn't be any current at all?
And second, if the device is moving with let's say 5 m/s and send out waves are the waves faster than when the device is not moving?
Thanks for answer
Philipp
Hi Philipp,
Let's say there is an underwater current with 10 m/s going right.
Yes, the speed of the waves relative to the still device would be given by simple addition of the speed of the waves relative to the water + the speed of the current.
No. The speed at which waves propagate in a medium is solely dependant on the medium itself. What will happen though is that since the source of the wave is moving, then the distance between two crests of the wave will be shorter or longer depending on wheter the source is moving towards the wave or away from them respectively. In other words, the wavelenght of the wave will be different. This phenomenon is called the Doppler effect.
As I said, the speed of the wave relative to the medium of propagation depends only on the physical properties of the medium. Some mediums, which we call dispersive mediums, have the property that the speed of a wave is dependant upon its wavelenght. As an exemple, water in the middle of the ocean (deep water) is dispersive, but water near the shore is non-dispersive. So if you are in deep water and give the source of your waves a speed such that the wavelenght is changed, the speed of the waves will be changed as well.
Mechanical waves move at a speed in the medium (which in this case is water) that is determined by its physical characteristics. If the medium is moving with respect to you (the observer), then the speed of the wave with respect to you will be the vector sum of the velocity of the wave with respect to the medium plus the velocity of the medium with respect to you.
Looks like quasar987 beat me too it!
I disagree with that consideration. Talking about fluid mechanics and not about the elastic wave propagated through a solid, there is a phenomenon called Advection. In this example, the waves are Advected by the fluid. It happens with superficial waves (shallow water waves as you referred) caused by flow over topography. In laboratory experiments, and solving analitically the subcritical flow over the obstacle, one can see two waves going upstream and downstream, each one with an absolute velocity U-\sqrt{gH} and U+\sqrt{gH} respectively.
In english? :biggrin:
Seriously, what you're saying sounds interesting but it is too technical for me to comprehend. Which parts of what I said do you disagree with, and with what would you replace the falacies?
Jokay,
what I am trying to say is that the bulk (the inertia) motion of the fluid adds an additional transport to waves. For instance, in linear acoustics the velocity of the fluid is so small compared with the speed of sound that one neglects such transport and in first approximation the waves move with the propagation speed c, which as you said it may only depend on the properties of the medium. Linear acoustics is employed with waves in water (c depends on the elastic properties) and low mach gases (c depends on the local temperature, but if one assumes isentropic flow the flow ends up to be isothermal because of the incompressibility assumption). In non linear acoustics, when the velocity is of the same order than the speed of sound, the transport of waves by means of advection or convection cannot be neglected, and in fact one can see the effective velocity of propagation looking at the Riemann equation of non linear acoustics, where it appears transported scalars like F(x-(U+ct) and so on (U is the bulk velocity of the fluid).
To sum up:
- If U/c<<1, which is the case of linear acoustics the waves are transported with the wave speed at first approximation.
-If U/c\sim O(1) or larger, the waves are transported with the wave speed plus the bulk velocity of the fluid.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
