Ways to bend radiation question?
  • Thread starter Thread starter philrainey
    Bend Radiation
Radiation, particularly electromagnetic radiation, can be influenced by gravity and matter, while particle radiation like beta decay can also be affected by electromagnetic fields. The discussion highlights the bending of radiation through gravitational forces, such as near black holes, and questions whether electromagnetic radiation is affected by electric or magnetic fields. Heat radiation is mentioned as a specific example, with temperatures potentially producing visible light. The term "radiation" is defined as the emission of particles or electromagnetic rays during nuclear decay, emphasizing its role as an energy transfer method. Overall, the conversation explores the complexities of how different types of radiation interact with various forces and fields.
philrainey
I'm fascinated by radiation as I have been learning a tidy bit about it. I have learned that radiation can be bent by refraction and have heard some idea that it can be bent by gravity ie a black hole. What other things bend electromagnetic radiation? Does electromagnetic radiation get bent passing through a magnetic field or a electrical field. Since this is what these waves are made of I thought perhaps they may be affected by these fields. Are there other effects that bend electromagnetic radiation?
Science news on Phys.org
What kind of radiation are you referring too? The word radiation can be define as: "the spontaneous emission of a stream of particles or electromagnetic rays in nuclear decay" which really is just a method of energy transfer. EM radiation can be manipulated only by gravity and matter, as far as I know (not far). While particle radiation, such as beta decay, can be manipulated by mass, gravity, and EM fields.
I don't know about the "jelly vacuum" theory, I've never heard of it.
I'm thinking about heat radiation across a vacuum from a hot body (say 3000 degrees C to a cold body (say 1500 degrees C). I suppose at that temperture some of it will be visable light?
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
