Weak field Newtonian limit
lailola
Hello,
I have to calculate the gravitational field strength g given by the De Sitter-Schwarzschild spacetime.
If G=c=1 I get:
R_{00}\simeq -kT_{00}+\frac{1}{2}kT\eta_{00}+\Lambda \eta_{00}\simeq
-kT_{00}+\frac{1}{2}kT_{00}\eta^{00}\eta_{00} +\Lambda \eta_{00}\simeq -\frac{1}{2}kT_{00}+ \Lambda =-\frac{1}{2}k\rho+ \Lambda
On the other side:
R_{00}\simeq -\Gamma_{00,j}^j \simeq -\frac{1}{2}\bigtriangledown^2g_{00}\simeq -\bigtriangledown^2 \phi
Equaling:
\bigtriangledown^2 \phi=\frac{1}{2}k\rho-\Lambda=4piG\rho-\Lambda
The first problem I have is that I don't know how to get this result in normal units, and the second problem is that, from here, I have to find the gravitational field strength g, and I don't know how to do it.
thanks for any help!
What precisely are "normal units"? I would say the units as you use here are just fine. Second, the gravitational field strength is given by
<br /> g^i \equiv \partial^i \phi <br />
whereas you have found an expression for \partial_i \partial^i \phi. Looking at the general method to solve the Poisson equation for lambda=0 should help you, e.g. here:
http://cass.ucsd.edu/~ppadoan/new_website/physics105b/Lecture3.pdf
You have an extra constant, which modifies this solution. See also
http://arxiv.org/abs/gr-qc/0004037,
eqn.2.6.
With 'normal' units I mean G=c=1
eqn.2.6.
Thank you haushofer, those links have helped me a lot.
Well, there is no c in your equations, so that's easy: just put G=1 :P
Glad I could help :)
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
