- 7,851
- 4,220
I think you are focusing on the wrong thing. I encode some information on a memory stick and give it to you. Instead of focusing on a string of '1' and '0' numbers, let's pretend the memory stick encodes base 27: all lowercase letters and a space.
Two preliminaries: I have many more choices of 30-'bit' messages to send than I do 1-'bit' messages. In fact, there are only 2 1-bit messages possible: 'I' and 'a'. There are considerably more 30-bit long strings I can send. So you, the receiver, ascribe more entropy to the 30-bit long message than the 1-bit message. Also, there is differences in uncertainty if you are reading along and encounter (for example) a 'q' rather than a 'c': 'q' is almost always followed by 'u', while 'c' can be followed by many more letters.
Now, before you object that the information in the code is 'observer dependent' becasue I chose english text, the above argument can be brought back to 1's and 0's by me sending you a (binary) message which is the sequence of coin flips, 1 = heads, and 0= tails. There are many more possible results of 30 coin flips than 1 coin flip, although you lose the notion of 'predictability'.
The entropy is defined the exact same way it usually is in statistical mechanics: S = -Sum(p log p).
I can encode messages all kinds of ways; it is possible to use entropy to determine the most efficient way of coding by calculating Sum(p log p):
http://en.wikipedia.org/wiki/Huffman_coding
