Weightless Speed: Find V for Bump Radius 35m
  • Thread starter sweetshelly
  • Tags
    Speed
In summary, for the first question, to be weightless over a speed bump, the car must maintain a speed of 19m/s. For the second question, the angle of the string with the vertical is 18.7 degrees and the tension in the string can be found using the formula for centripetal force. For the third question, the correct answer is b) the ball has a total force acting on it that is not zero. And for the fourth question, the box will move at a constant speed due to the equal and opposite forces of kinetic friction and the horizontal pushing force.
sweetshelly
Question 1:
At what speed must you go over a speed bump if people in your car are to feel weightless?
car speed V=12m/s
bump radius 35m
I don't know how to approch this problem. please help?
Question2:
A 0.075kg toy airplane if tied to the ceiling with a string. When the airplane's motor is started, it moves with a constant speed of 1.21m/s in a horizontal circle of radius 0.44m
a) Find the angle the string make with the vertical
b) the tension in the string
I found the answer to a. What I did was use the formula
Thea=tan-1(Vsquare/gr)
V=1.21m/s
g=9.81m/s square
r=0.44m
So the answer is 18.7 degree
How do I slove for the tension of the string?Question 3:
A monkey swings a ball tied to a string in a circle over her head at constant speed. The ball:
a. has total force acting on it that is zero.
b. has a total force acting on it that it is not zero.
c. has an acceleration that is zero. (not C because constantly have accer because constanly changing direction)
d. has a constant velocity.
Question 4:
A box is pushed along a horizontal surface with a horizontal force that is equal in magnitude to the force of kinetic friction between the box and surface. In this case:
a. the box's speed will decrease at a constant rate.
b. the box's speed will increase at a constant rate.
c. the book will not be able to move, because the coefficent of static friction must exceed the coefficient of kinetic friction.
d. the box will move at constant speed.
At what sppeed must you go over the bump if people in your car are to feel weightless?
car speed V=12m/s
bump radius 35m
Kind of a strange question since it asks for speed and then it gives 12 m/s.
Think of centripetal acceleration, v2/r, which must equal the acceleration of gravity.
acp=v2/r
solve (12square)/(35)= 4.11
This is not the answer because in the back of the book it say that the answer is 19m/s.
What other way can I solve this problem?
To be weightless on arc of R, the centripetal acceleration must = g = 9.8 m/s2,
so g = v2/R => gR = v2 => v = sqrt (gR). Perhaps the textbook rounds up.
v = sqrt (gR) = .52915
nope still not the answer we are looking for. Which in this case is 19m/s (textbook answer)
What else can we do?
What numbers did you use?
g = 9.8 m/s2 and R = 35 m.
How are you doing on the other problems?
The 0.075kg plane produces a centripetal force in the circular plane (horizontal). Think of the formula for centripetal force.
Now the string is at some angle with respect to the plane. The tension in the string acts along the string, and it is pulling on the plane. One must find the component of centripetal force which is parallel with the string.
1. How is weightless speed defined?
Weightless speed is defined as the velocity at which an object or person experiences an apparent weight of zero. This means that the object or person at this speed will feel weightless, as if they are floating in space.
2. What is the significance of finding V for a 35m bump radius?
The bump radius of 35m is significant because it is the distance at which an object or person would experience weightlessness. This means that if an object or person travels at a certain velocity around a 35m radius bump, they will feel weightless at that specific velocity.
3. How is V (velocity) calculated for a 35m bump radius in weightless speed?
V (velocity) for a 35m bump radius in weightless speed can be calculated using the formula V = √(gR), where g is the acceleration due to gravity and R is the radius of the bump (in this case, 35m).
4. Can weightless speed be achieved on Earth?
Yes, weightless speed can be achieved on Earth with the right conditions. For example, astronauts in orbit around Earth experience weightlessness because they are constantly falling towards the Earth at the same rate that the Earth's curvature is falling away from them.
5. Are there any potential dangers associated with weightless speed?
Yes, there are potential dangers associated with weightless speed. The main danger is the possibility of losing control and going off course, which can result in collisions or other accidents. Additionally, rapid changes in acceleration, such as when going from weightless to non-weightless states, can cause discomfort and disorientation.
