Weinberg, QTF, pg 60:very specific question
  • Thread starter Thread starter Living_Dog
    Specific Weinberg
Living_Dog
I have been able to read through up to here (middle of pg. 60). The instructions given are not clear: (I arranged the text so as to be easier to read on the page here.)
"Next, let's apply rules (2.4.8), (2.4.9)
Eq. (2.4.8): U(\Lambda,a)J^{\rho\sigma}U^{-1}(\Lambda,a) = \Lambda_{\mu}^{\rho}\Lambda_{\nu}^{\sigma}(J^{\mu\nu} - a^{\mu}P^{\nu} + a^{\nu}P^{\mu})
Eq. (2.4.9): U(\Lambda,a)P^{\rho}U^{-1}(\Lambda,a) = \Lambda_{\mu}^{\rho}P^{\mu}
to a transformation that is itself infinitesimal, i.e.,
\Lambda^{\mu}_{\nu} = \delta^{\mu}_{\nu} + \omega^{\mu}_{\nu}
and
a^{\mu} = \epsilon^{\mu}...
Using Eq. (2.4.3),
Eq. (2.4.3): U(1 + \omega , \epsilon) = 1 + \frac{1}{2} i \omega_{\rho\sigma} J^{\rho\sigma} - \epsilon_{\rho} P^{\rho} + . . .
and keeping only terms of first order in \omega and \epsilon Eqs. (2.4.8) and (2.4.9) now become
Eq. (2.4.10): i [\frac{1}{2} \omega_{\mu\nu} J^{\mu\nu} - \epsilon_{\mu} P^{\mu} , J^{\rho\sigma}] = \omega_{\mu}^{\rho} J^{\mu\sigma} + \omega_{\nu}^{\sigma} J^{\sigma\nu} - \epsilon^{\rho} P^{\sigma} + \epsilon^{\sigma} P^{\rho}
and
Eq. (2.4.11): i [\frac{1}{2} \omega_{\mu\nu} J^{\mu\nu} - \epsilon_{\mu} P^{\mu} , P^{\rho}] = \omega_{\mu}^{\rho} P^{\mu}."
This may be a shot in the dark, but if I don't ask, I'll never know.
Thanks in advance!
The instructions tell you to replace every a^\mu in (2.4.8) and (2.4.9) with \epsilon^\mu, and every \Lambda^\mu{}_\nu with \delta^\mu_\nu+\omega^\mu{}_\nu.
This turns (2.4.8) into
(1+\frac i 2\omega_{\alpha\beta}J^{\alpha\beta}-i\epsilon_\alpha P^\alpha)J^{\rho\sigma}(1-\frac i 2\omega_{\gamma\delta}J^{\gamma\delta}+i\epsilon_\gamma P^\gamma)=(\delta^\rho_\mu+\omega^\rho{}_\mu)(\delta^\sigma_\nu+\omega^\sigma{}_\nu)(J^{\mu\nu}-\epsilon^\mu P^\nu+\epsilon^\nu P^\mu)
Looks like you forgot an i. I may have introduced some typos on my own though. These things have to agree order-by-order in each variable, just like two polynomials that are equal for all values of all the variables. (Wouldn't that mean that they're the same polynomial? Yes it would, that's the point). The zeroth order terms are
J^{\rho\sigma}=\delta^\rho_\mu\delta^\sigma_\nu J^{\mu\nu}
Next, consider the terms that are of first order in components of \omega.
(I have to leave the computer for a while, but I might post those details in a couple of hours).
Also, make sure you understand the stuff in this post (about the notation) perfectly.
Edit:
\frac i 2\omega_{\alpha\beta}J^{\alpha\beta}J^{\rho\sigma}-J^{\rho\sigma}\frac i 2\omega_{\gamma\delta}J^{\gamma\delta}=\omega^\rho{}_\mu\delta^\sigma_\nu J^{\mu\nu}+\delta^\rho_\mu\omega^\sigma{}_\nu J^{\mu\nu}
\frac i 2\omega_{\alpha\beta}[J^{\alpha\beta},J^{\rho\sigma}]=\omega^\rho{}_\mu J^{\mu\sigma}+\omega^\sigma{}_\nu J^{\rho\nu}
Looks like you got an index wrong in the last term on the right.
Weinberg kept all of the first order terms, so to get his result you repeat the above for terms of first order in \epsilon and add the result to the result I got. Then do the same for (2.4.9).
D'OH! I didn't associate the Unitary operators of (2.4.8) and (2.4.9), U(\Lambda,a) and U^{-1}(\Lambda,a), with (2.4.3)!
I kept thinking that the \Lambda's were being replaced ("...itself...") That's what I was missing... the forest for the trees.
And yes, I dropped an 'i' for the \epsilon_\rho P^\rho term of (2.4.3).
No need. I was confused by that one term only and the rest should be straight forward. I actually find the indexing to be helpful.
Fredrik said:
Also, make sure you understand the stuff in https://www.physicsforums.com/showthread.php?p=2367047" (about the notation) perfectly.
That was another question I had! How could the 2 LT's go from a forward and an inverse boost to 2 inverse boosts?
\emph{A million thanks!}
U(\Lambda, a) \rightarrow U(1 + \omega, a) \approx 1 + \frac{i}{2}\omega_{\rho\sigma}J^{\rho\sigma} - i\epsilon_\rho P^\rho + ...
then how does one write
U^{-1}(\Lambda, a)??
U^{-1}(\Lambda, a) \rightarrow U^{-1}(1 + \omega, a) \approx 1 - \frac{i}{2}\omega_{\rho\sigma}J^{\rho\sigma} + i\epsilon_\rho P^\rho + ... ?
Since
{\Lambda^\mu}_\nu = \delta^\mu_\nu + {\omega^\mu}_\nu
then
{(\Lambda^{-1})^\mu}_\nu = {\Lambda_\nu}^\mu = \delta^\mu_\nu + {\omega_\nu}^\mu
But how is this incorporated into
U^{-1}(\Lambda, a) ??
(Sorry, I thought I could do the details by myself.)
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
If we release an electron around a positively charged sphere, the initial state of electron is a linear combination of Hydrogen-like states. According to quantum mechanics, evolution of time would not change this initial state because the potential is time independent. However, classically we expect the electron to collide with the sphere. So, it seems that the quantum and classics predict different behaviours!
According to recent podcast between Jacob Barandes and Sean Carroll, Barandes claims that putting a sensitive qubit near one of the slits of a double slit interference experiment is sufficient to break the interference pattern. Here are his words from the official transcript: Is that true? Caveats I see: The qubit is a quantum object, so if the particle was in a superposition of up and down, the qubit can be in a superposition too. Measuring the qubit in an orthogonal direction might...
