What all factors decide which chemicals to use?
  • Thread starter Thread starter jd12345
    Chemicals Factors
In the discussion, the use of specific chemicals in processes like thermite welding and rocket propellant is analyzed. For thermite welding, aluminum is preferred over sodium due to its lower melting point, higher boiling point, cost-effectiveness, and ease of handling. In rocket propulsion, hydrogen peroxide is favored for its practical advantages, such as not requiring cryogenic storage and ease of cleanup. The conversation emphasizes that factors like cost, safety, and relevant physical and chemical properties are crucial in selecting chemicals for these applications.
jd12345
I was studying what kind of chemicals are used in various processes like thermite welding , rocket propellant. On what basis are these chemicals used?
In welding Al + Fe2O3 is used. Why not Sodium and some weaker oxide as sodium is an alkali metal and highly reactive
In rocket propeller H2O2 is used, why not some stronger oxidising agent?
Chemistry news on Phys.org
For the welding example, any reactive metal - in principle - could do the job. Practically, aluminum has certain advantages in this case over something like sodium - its melting point is lower than sodium's but its boiling point is higher. It is also extremely inexpensive and easy to handle compared to sodium.
I don't happen to recall anything significant about rocket propellants at the moment, but I am sure that there are/were practical advantages to using hydrogen peroxide (doesn't require cryogenic storage, I imagine that on a small scale it's easy to clean up any spills with adequate water).
In general, these sorts of factors - cost, safety, specific physical/chemical properties relevant to its intended application - and others are what one needs to consider.
It seems like a simple enough question: what is the solubility of epsom salt in water at 20°C? A graph or table showing how it varies with temperature would be a bonus. But upon searching the internet I have been unable to determine this with confidence. Wikipedia gives the value of 113g/100ml. But other sources disagree and I can't find a definitive source for the information. I even asked chatgpt but it couldn't be sure either. I thought, naively, that this would be easy to look up without...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
