What Angle Should a Cannon Be Fired to Hit a Target 2000m Away and 800m High?
The discussion focuses on calculating the optimal angle for firing a cannon to hit a target located 2000 meters horizontally and 800 meters vertically above the cannon. The cannon has a muzzle speed of 1000 m/s. The solution involves breaking down the projectile motion into two components: horizontal and vertical. By establishing two equations based on the horizontal and vertical displacements, users can solve for the angle of projection and time of flight.
  • Understanding of projectile motion principles
  • Familiarity with trigonometric functions
  • Knowledge of kinematic equations
  • Basic algebra for solving equations
  • Study the derivation of projectile motion equations
  • Learn how to apply trigonometric identities in physics problems
  • Explore the effects of air resistance on projectile motion
  • Investigate advanced projectile motion simulations using software tools
Physics students, engineers, and anyone interested in solving projectile motion problems or optimizing cannon firing angles for specific targets.
specwarop
Okay another projectile motion question. I'm a bit confused by how to work this out.
A cannon will a muzzle speed of 1000m/s is used to start an avalanche on a mountain slope. The target is 2000m from the cannon horizontally and 800m above the cannon. At what angle, above the horizontal, should the cannon be fired?
I was thinking that i would have to work out the angle to which the cannon should fire if the target was at its vertical level, 2000m away horizontally. Then somehow (i don't know how), using this angle in a further equation, that i don't know of, to include the difference in height?
Can anyone help?
Regards.
The trick (as always) is to consider each component of motion separately. you should then have two equations with two unknowns (time and angle). You can substitute out on of the unknowns and find the other.
You should always solve the projectile problem like this :
Let it be projected at angle 'x' with horizontal. Then at instantaneous time 't' :
Along X- Direction
u=1000cosx
a=0
v=1000cosx
s=1000cosxt
Along Y- Direction
u=1000sinx
a= -g
v=1000sinx-gt
s=1000sinxt-1/2gt2
Your displacement along x-direction will be
1000cosxt
According to question
1000cosxt=2000----------(1)
Your displacement along y-axis will be
1000sinxt-1/2gt2
According to question,
1000sinxt-1/2gt2=800------(2)
Now you can solve as you have two equations( 1 & 2) and two variables x and t.
  • · Replies 19 ·
