What Are Eigenvalues and Eigenspaces in Linear Transformations?
  • Thread starter Thread starter derryck1234
    Eigenvectors
derryck1234
Let T: M22 - M22 be defined by
T(a b = 2c a + c
c d) b-2c d
(a) Find the eigenvalues T.
(b) Find bases for the eigenspaces of T.
det(lambdaI - A) = 0
I just wanted to know how to start here. I am used to using vector transformations...
Would I use identity matrices 1 0 0 1 0 0 0 0
0 0 0 0 1 0 0 1
And then form a matrix somehow? I just don't know how big or how this matrix would be formed...?
One small thing: you shouldn't call the matrices
[tex]\left(\begin{array}{cc} 1 & 0\\ 0 & 0\end{array}\right), \left(\begin{array}{cc} 0 & 1\\ 0 & 0\end{array}\right), \left(\begin{array}{cc} 0 & 0\\ 1 & 0\end{array}\right), \left(\begin{array}{cc} 0 & 0\\ 0 & 1\end{array}\right)[/tex]
identity matrices. We reserve the term identity matrix for something else.
You can call them elementary matrices however.
Anyway, your approach is good: try to find the images of the elementary matrices to find the matrix form of T. T will have the form of a 4x4-matrix.
Ok. So I find the matrix for T to be:
0 1 0 0
0 0 1 0
2 1 0 0
-2 0 0 1
The characteristic equation of which I find to be:
(lambda)4 - (lambda)3 - (lambda)2 - (lambda) + 2
Just wondered if there was an easy way to solve this?
0 1 0 0
0 0 1 0
2 1 0 0
-2 0 0 1
Hmm, that's not what I get:
[tex]T\left(\begin{array}{cc} 1 & 0\\ 0 & 0\end{array}\right)=\left(\begin{array}{cc} 0 & 1\\ 0 & 0\end{array}\right)[/tex]
So the first column needs to be (0,1,0,0), no?
O ok. So I must turn the resulting matrix into a column vector? I just put them together as matrices...my bad...ok I shall try this agen...shall get back to you to confirm my answer...thanks a lot...
Ciao...I feel mentally ill that I am such a dumb ***!...but then again...have to learn somehow...
Ok I think I have solved it:
The standard matrix for T is:
0 0 2 0
1 0 1 0
0 1 -2 0
0 0 0 1
Whose characteristic equation is:
(lambda - 1)2(lambda + 1)(lambda + 2) = 0
This right?
Thanks
Derryck
0 0 2 0
1 0 1 0
0 1 -2 0
0 0 0 1
This right?
Thanks
Derryck
Yes, that's also what I've got!
Thanks a lot micromass
Tell you what if it wasn't for physicsforums I don't know how I would have passed my correspondence linear algebra course...
Cheers
Derryck
  • · Replies 19 ·
  • · Replies 24 ·
