What are some common challenges faced in chemistry problem solving?
  • Thread starter Thread starter dude_007
    Chem Desperate
The discussion addresses various chemistry problem-solving challenges, including calculations involving atomic mass, chemical reactions, and stoichiometry. Participants express confusion over specific problems, such as determining the mass of 31^P atoms and calculating the percentage of compounds in mixtures. There is a focus on the need for correct particle mass values and balancing chemical equations to solve the problems effectively. Users are encouraged to show their reasoning and calculations to receive constructive feedback. Overall, the thread emphasizes collaborative learning and the importance of understanding fundamental concepts in chemistry.
dude_007
a) Calculate the expected mass of one mole of 31^P atoms that the avogadro constant equals 6.0225 x10^23, the mass of one electron equals 9.1091x10^-28g, the mass of one proton equals 1.6725x10^-24g and the mass of one nuetron equals 1.6748x10^-24g.
b) The actual mass of one mole of 31^P atoms is 30.9738g. Try to account for the difference between this valueand your answer in (a).
3.
A mixture of MGS04 and CuSO4.7H20 is heated at 120(degrees C) until a mixture of the anhydrous compounds is produced. If 5.00g of the mixture gave 3.00g of the anhydrous compounds, calculate the percentage by mass of MGSO4.7H20 in the mixture.
4.
1 mole of a hydrocarbon formula CnH2n was burned completely in oxygen producing carbon dioxide and water vapour only. It requires 192g of oxygen. Work out the formula of the hydrocarbon.
5. When 15cm^3 of gaseous hydrocarbon was exploded with 60cm^3 of oxygen (an XS), the final volume was 45cm^3. This decreased by 15cm^3 on treatment with NaOH solution ( removes C02 ). What was the formula of the hydrocarbon (all measuremnets were made at room temp. and pressure, & water produced is liquid)
6.
A fertilser contains ammonuim sulphate and pottasuim sulphate. A samply of 1.455g of the fertilise was warmed with 25cm^3, 0.2moddm^-3 NaOH solution giving of ammonia gas. The remaining NaOH that was not used requireed 28.7cm^3 of 0.100moldm^-3 HCl acid for nuetrulisation. Calculate the % by mass of ammonuim sulphate in the sample
I HAVE NO IDEA HOW TO DO ANY OF THESE PLEASE HELP ME I HAVE UNTIL FRIDAY
Chemistry news on Phys.org
Can you show of the work/thinking/reasonning you have done on these problems. People will point out the errors and they help you solve your problem.
We are here to help but we are not here to do your homework.
Hint; in the first question all three particle masses are incorrect, some by small amount, some large.
The others; you have some digging to do.
sorry i now done 2ab and no. 5
3-
no real working outs because all i cud figure out that 2g of water had been extracted.
6-
I "think" its all a 1-1 ratio equation, so i found out moles of NaOH but then couldn't find mass because i don't no a; if the equation is balance b;the Mr of the ammonuim sulphate.
5-
I tried to use the pv=nrt forumula to work out the amount of moles used, after that i was lost on wat to do
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
