What are the dimensiosn of tank in meters
  • Thread starter Thread starter Makaroon
    Tank
To determine the dimensions of a cubic tank that holds 1,000.0 kg of water, it's essential to know the density of water, which is approximately 1,000 kg/m³. This means the volume of the tank is 1 cubic meter. The formula for the volume of a cube is V = side³, leading to the conclusion that each side of the cube measures 1 meter. The discussion highlights confusion about the problem and seeks guidance on how to apply the relevant formulas. Understanding the relationship between weight, volume, and density is crucial for solving this homework problem.
Makaroon
A cubic tank holds 1,000.0 kg of water. What are the dimensiosn of tank i meters.
n/a
ok so its a cube therefore its six sides.
do you use the lateral?
ahh i am so lost...
i am sorry the profesor gave us notes, but they are not related to this...
he gave like d/v.
but i am lost... =/
can you please guide me to the answer! pleasee
One piece of information you need to know to solve this problem is the density of water, which will turn your weight into a measurement of volume (you can look this up easily).
Then you know that there is a cube holding a known volume of water. So.. what's the formula for the volume of a cube?
