What Are the Loci for Different Values of Lambda in a Complex Equation?
14 replies · 3K views
Alettix
Consider the relation ## |\frac{z-i}{z*-i}| = \lambda ## where z = x + yi
a) For ##\lambda = 1## show that the locus is a line in the complex plane and find its equation.
b) What is the locus when ##\lambda = 0##?
c) Show that for all other positive ##\lambda## the locus may be written as ##zz* + bz* + b*z + c = 0## where ##c## is a real number. Find conditions on complex #b# and real #c# for which the expression describes a
i) Point
ii) Circle
iii) Line
## \frac{m}{n} = \frac{mn*}{|n|^2}##
if ## m = k + ip ##, ##|m| = \sqrt{k^2+p^2}##
I tried the following on the first part:
## 1 = |\frac{z-i}{z*-i}| = |\frac{x+i(y-1)}{x-i(y+1)}| = |\frac{(x+i(y-1))\cdot (x+i(y+1))}{x^2+(y+1)^2}| = |\frac{x^2-y^2-2xyi}{x^2+(y+1)^2}| ##
but from here I am stuck, because this does not resemble the equation of a line at all.
Thanks for all help and hints! :)
on Phys.org
i) Point
ii) Circle
iii) Line
For the first part, with ##\lambda = 1##, you have ##|\frac{z-i}{\bar{z}-i}| = 1##, or equivalently, ##|z - i| = |\bar{z}-i|##. Simplify this equation by replacing z and ##\bar{z}##, and by taking magnitudes on each side.
Right! That seems easier! So then we have:
## x^2 + (y-1)^2 = x^2 + (y+1)^2 ##
## y^2 -2y +1 = y^2 + 2y +1 ##
## y = 0##
Thus the loci of all z must be the real axis?
For part b) then: ##|z-i| = 0## requires z=i, thus the loci is a single point?
in c) I have the following:
## \sqrt{(z-i)(z*+i)} = \lambda \sqrt{(z*-i)(z+i)} ## yielding:
##(\lambda^2 -1)z*z - (\lambda^2+1)i z + (\lambda^2+1)iz* + (\lambda^2-1) = 0 ##
but I am not sure how I should derive the conditions for the different loci.
Inserting ##z = x +yi## in ##z^*z + bz^* +b^*z + c = 0 ## and noting ##b = -b^*## and ##c=1## simply yields: ##x^2 + y^2 + 1 = 0## which is the equation of a parabola...
## y = 0##
Yes on both a) and b).
I haven't looked at c) yet, but will do so now.
haruspex said:
Check that step
Well: ##z^*z + bz^* +b^*z + c = x^2+y^2+bx-by+b^*x+b^*y +c = 0 ##
noting ##b = -b^*## and ##c=1## gives ##x^2+y^2+c=0##
which is ##x^2+y^2+1=0##
What am I doing wrong?
Umm.. No it isn't.
Sorry, I meant hyperbola!
SammyS said:
Why did you choose ##\ c=1\,?##
I didn't choose it, it followed from ##(\lambda^2 -1)z*z - (\lambda^2+1)i z + (\lambda^2+1)iz* + (\lambda^2-1) = 0 ## assuming ##\lambda \ne 1##
haruspex said:
You are cancelling a zb with a z*b.
Not that either.
Sorry, my bad!
It should be: ##x^2 + y^2 - 2bi y + 1 = x^2 +y^2 + 2|b|y + 1 = 0## which can be written as ##x^2 + (y+|b|)^2 = |b|^2 - 1##. Which is the equation of a circle. This becomes a point if ##|b|^2 = 1##. But how can this be made a line?
i) Point
ii) Circle
iii) Line
Use geometry! ##|z-i|## is the distance of the point ##(x,y)## from the point ##(0,1)## in the Cartesian plane. ##|z^*-i| = |(z^*-i)^*| = |z+i|## is the distance from ##(x,y)## to ##(0,-1)##.
So, for (a), you want all the points ##(x,y)## that are the same distance to the two points ##(0,1)## and ##(0,-1)##.
For (b) you want ##d[(x,y) \to (0,1)]= 0\, d[(x,y) \to (0,-1)] = 0##. For (c) you want ##d[(x,y) \to (0,1)] = \lambda d[(x,y) \to (0,-1)]##, or
##d[(x,y) \to (0,1)]^2 = \lambda^2 d[(x,y) \to (0,-1)]^2.## Expand this equation out in terms of powers of ##x## and ##y##, to see what you get.
haruspex said:
To arrive at this equation you made an assumption about λ, remember?
Yes, I assumed that ##\lambda >1##. This also means that I cannot insert ##lambda = 1## (which gave a line) into my ##z^*z + bz^* +b^*z + c = 0 ## equation, because in that case ##b## diverges. Therefore I am not really sure how to find the conditions of a line.
Sorry, I overlooked that it was asking for conditions on b and c, so is specifically in the context of λ≠1. As you found, it can never be a line, though it does tend to a line in the limit as b tends to infinity.
Got it! Thank you very much!
