What came first Gravity or Curvature
AKT
I understand that Gravity is the result of spacetime curvature. All planets are spherical(almost). Planets are spherical because of gravity (partially true at least). So, seriously, what came first? If we have just mass of gas - how would it become spherical -if gravity were only because of the geometry, i.e, gravity would come into picture only after the mass of gas takes the shape of sphere?
GR tells us the relationship between the geometry of spacetime and the motion of matter in it. It's not possible in general to specify one of those things and then determine the other thing from it. They affect each other. If you have found a solution already, and change the motion of matter slightly, this gives you a new geometry, which makes matter move in a different way, which changes the geometry again, which...you get the idea. This is the main reason why it's so hard to find solutions of Einstein's equation.
Interstellar gas would float around in relatively "empty" space and as more particles approach one another spacetime gradually curves...equivalently, one could say spacetime is curved ever so slightly by gas molecules and as they drift and are "attracted" to one another they move along a curved spacetime curvature which tends to bring them together.
on the other hand, spiral galaxies are very common and do not represent 'spherical" formation shapes...but maybe when dark matter is accounted for, the total IS rather spherical...anybody know?? Last illustration I saw pictured dark matter as spider web type formations in space.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
