What Can Induce Electron Flow and Why Are Magnets So Dominant?
The discussion revolves around the various methods of inducing electron flow to generate electricity, with a particular focus on the dominance of magnetic fields in this process. Participants explore theoretical and practical aspects of electricity generation, including different mechanisms and their efficiencies.
  • Some participants identify three primary methods to induce electron flow: light (photovoltaic cells), chemical reactions (batteries, fuel cells), and magnetic fields (turbines).
  • Another participant adds additional methods, including thermocouples, piezoelectric materials, and even biological sources like electric eels.
  • One participant emphasizes that rotating a magnetic field around a wire is a prevalent method for electricity generation, suggesting it accounts for a significant portion of global power generation.
  • Concerns are raised about the efficiency and environmental impact of wind turbines compared to other methods, with some arguing that they are currently less impressive and more expensive.
  • Another participant discusses the mechanical manipulation of magnets and their role in converting kinetic energy into electric current, suggesting this is a unique advantage of magnetic methods.
  • A later reply challenges the environmental impact of hydroelectric power stations, particularly regarding the concrete used in their construction and the associated carbon emissions.
  • Participants discuss the cost-effectiveness of various energy sources, with some arguing that natural gas is currently the cheapest, followed by hydroelectric power and then wind energy.
Participants express a range of views on the efficiency and environmental impact of different electricity generation methods, particularly regarding wind turbines and hydroelectric power. There is no consensus on the superiority of one method over another, and multiple competing perspectives remain present.
Participants note various assumptions regarding the efficiency of energy sources and the environmental impacts of construction materials, particularly concrete. Some claims about costs and efficiencies are based on specific data points, which may not encompass all variables involved.
mayble
I can think of three ways to induce electrons to flow and generate electricity:
1. Light (i.e. PV cells)
2. Catalyzed chemical reaction (batteries, fuel cells)
3. Magnetic field (turbines -- gas, wind, water, nuclear... everything else I can think of)
Mostly turbines. I was wondering if anyone could at to the list? Or could explain why magnets are so dominant?
Well.. turbines are only responsible of creating a rotating field - as only non-stationary field can create current flow (voltage actually -> Faraday's Law of Induction).
Why turbine + magnets (electromagnets, permeant magnets) are dominant ? Because it's cheaper to produce power this way. Large power density (~few W\kg).
Thermocouples
Piezoelectric materials
Muscles
Kelvins water dropper, cat fur
Electric eels :smile:
Well, when it comes to just causing electrons to flow, there are 6 ways I know of (general.)
Heat (thermocouples,) pressure (some crystals etc,) friction (static,) chemical (batteries,) solar (light,) and I believe the last one is magnetic.
I would post a more in depth explanation but I am on my phone. I can add more of an explanation later.
Certainly the most popular way to generate electricity is to rotate a magnetic field around a wire...also known as a generator. I would assume this generates at least 90% of the worlds power.
What drives that generator can be a number of things. Boiling a gigantic pot of water (usually heat created by coal or E=mc^2) and using the steam to drive a generator I would also think powers at least 90% of the worlds power. These giant pots of water can be 15 stories high and even higher.
Gigantic water falls (Hoover dam for example) also make a lot of power by turning generator. And these are certainly the best since the power source is free and the pollutants are near zero.
Wind turbines are inefficient, expensive and not overly impressive at this time.
All other forms are certainly important, but just subsets at the moment compared to the dominant rotating magnetic field.
I would say that this is because magnets are easy to manipulate mechanically, and any movement of a magnetical field entails a movement in an electric field.
Most of the energy generation methods used on a large scale involve a change of energy from one form (chemical, mass, kinetic) to kinetic; e.g. Chemical energy in coal is released as heat which is then converted to kinetic energy in steam.
Magnets seem to me to be the only to convert large amounts of kinetic energy into an electric current.
I question both statements. While the running of HEP stations does not require much energy input or pollutant output, the construction of a "gigantic water fall" involves "gigantic" amounts of concrete. Hoover dam, being your example, contains some 2,480,000 m3 of concrete. As concrete sets a chemical reaction takes place, emitting heat and carbon dioxide.
The carbon dioxide CO2 produced for the manufacture of one tonne of structural concrete (using ~14% cement) is estimated at 410 kg/m3
http://en.wikipedia.org/wiki/Enviro...e#Carbon_dioxide_emissions_and_climate_change
Hence the total amount of carbon dioxide emitted from the Hoover dam during construction could be in the region of 1,016,800 tons. I'm not saying HEP is an environmental disaster (quite the contrary) but don't be ignorant of it's impacts!
"Wind turbines are inefficient, expensive and not overly impressive at this time."
Typical commercial turbine: 2 MW in size and cost roughly $3-$4 million installed, which would be expected to run for about 120 000 hours. That's ~240,000,000 KWh, so roughly $0.016 per KWh. But I fear this is an under estimate, as NO wind turbine constantly runs at rated power, or anywhere near it!
http://en.wikipedia.org/wiki/Cost_of_electricity_by_source
Suggests $/KWh for wind is $0.097, so I was out by a factor of about 6 :biggrin:
Any way to the point... Natural gas is cheapest per unit energy, then HEP, then wind. So wind is not overly expensive.
Wind cannot be >56% efficient due to Betz' law, which basically uses the idea that the more efficient your wind turbine the slower the air after your turbine, which in turn slows the air before the turbine (which in turn lowers your power output). Read up on it, it's a great proof!
  • · Replies 39 ·
  • · Replies 22 ·
21K
