What Causes Galactic Plains?
  • Thread starter Thread starter M.C.
Galactic plains form primarily due to the gravitational interactions and collisions between galaxies, similar to how planetary plains develop. The orbits of planets within a solar system tend to align over time due to repeated gravitational interactions, which create a "viscosity" effect that gradually settles their angular momentum into a common plane. This process involves significant energy loss and angular momentum cancellation over millions of years. Both galaxies and star systems originate from large rotating clouds of gas and dust, which retain angular momentum as they condense, leading to a flattened structure. The alignment of planetary orbits with the galactic plane is influenced by localized turbulence during the gas cloud's condensation.
M.C.
What causes Galactic Plains to form? Is it the same reason there is a planetary plain?
Astronomy news on Phys.org
http://www.kingsu.ab.ca/~brian/astro/course/lectures/winter/chp11.htm
i think mosty due to collision between galaxies
so what causes the planetary plain?
I want to understand your question better
first of all, the plane of the Earth's orbit is not quite the same as the plane of jupiter's orbit
or the plane of another planet
or the plane of the moon's orbit
all these planes are slightly tilted with respect to each other and do not exactly coincide
but I think you are asking why do they so NEARLY coincide
mostly they are tilted only a few degrees from each other
what evened them out?
if you started with a central star and 100 planets orbiting every which way around it
so the orbit-planes of the 100 planets are initially all tilted randomly by as much as 90 degrees from each other or even more
then what would cause those 100 planets to gradually
work out an approximate common orbit plane?
wolram mentioned collisions
and there is gravitational interaction which can ressemble a soft-core collision and happen repeatedly over millions of years
maybe it gives a kind of "viscosity" to a system of 100 planets
so that eventually their angular momentums boil down and settle down to one basic orientation that they all more or less agree on
(because otherwise they keep bumping and perturbing each other)
a lot of energy must get lost and a lot of angular momentum (in opposed directions) must get canceled out and it must be a long process (wouldnt necessarily be pleasant to witness either)
but something like viscosity keeps dragging on them and bugging them until they work out an approximate common plane
Let us try to get Phobos or Integral or some such astronomy honcho to pronounce the word on this
My guess would be that galaxies are planar for the same reason as star systems - they formed out of large rotating clouds of gas and dust. As the gas condenses, it retains its angular momentum and "settles down" to a plane. It's similar to the oblateness of the Earth due to its rotation, but taken to an extreme due to the gaseous nature of the cloud and the speed of rotation (Earth's surface rotates at about 1 kps; gas at 1AU goes around at about 30kps). I believe we are going around the center of the galaxy at about 200 kps, so despite the massive size it would still flatten out on a timescale of billions of years.
As a side note, how tilted is the ecliptic with respect to the galactic plane? What about for the orbits of extrasolar planets? I suspect that planetary orbits would be, for the most part, similar to the galactic plane, differences being due to localized turbulence in the original gas cloud as it was condensing.
Ok, I understand it now. Thanks for the information guys:smile:
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
