What causes the warping of spacetime?
  • Thread starter Thread starter gravityquantum11
    Spacetime
gravityquantum11
I understand that large objects that have an extreme amount of mass results in the warping of space-time, however my question is more fundamental than that.
I'm wondering why the presence of mass causes the warped space-time. Is there an intrinsic property within mass that causes this warping or can it be explained by the math?
Thanks
It turns out that mass, stress, pressure and energy all cause spacetime to warp, that is curve. It also turns out that certain types of curvature, Wyle and Ricci curvatures, offer mathematical expressions that accurately predict outcomes. Einstein had physical insights into the types of spacetime curvature he expected and with the help of others with some of the math was able to formulate mathematics that very accurately modeled such phenomena.
The sciences doesn't usually explain 'why' things happen. Seems like most of that is hidden from our view. It's a wonder that man can produce math that explains as much as it does.
All mass has energy, so the stress energy tensor is non zero. That is the source of gravity in GR.
Are you using "mass" and "matter" synonymously? Mass is a property of matter. Humans invent properties, but we didn't invent matter.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
