What Color is the Bear's Snowball Adventure?
  • Thread starter Thread starter Icebreaker
A bear walks 1 kilometer south, 1 kilometer east, and then 1 kilometer north, returning to its starting point, which leads to the conclusion that the bear is at the North Pole. The bear is white, as polar bears inhabit this region. The discussion explores the implications of Earth's spherical shape, noting that the path taken creates a triangle with angles that can exceed 180 degrees due to the curvature of the Earth. Participants clarify that while the North Pole is a specific solution, there are other locations where similar movements could occur, although these do not involve bears, as no bears exist at the South Pole. The conversation also touches on the possibility of multiple solutions and the nature of triangular geometry on a sphere, emphasizing that only two right angles are necessary to return to the starting point, rather than three.
Icebreaker
A bear starts out from a point, walks 1 kilometer due south, then changes its direction and walks 1 kilometer due east, then changes its direction once again and walks 1 kilometer due north, and ends up at the point where he began. What is the color of the bear?
Same color as this reply
Yup. Why is that?
b coz he is at the north pole. and all bear that naturally found in north pole are white.
No, why is he found at the north pole?
See my bad MS Paint drawing.
bah. humbug.
it is because the shape of the Earth is round like a ball. and he is going south,west and north direction instead of backward, leftward and foward direction.
and also the longitude of the Earth meet and one poin instead of always pararel like it's latitude.
i posted the exact same question only harder not too long ago. it was called mr. fubini. you can look there if you are confused because there is a nother solution
it goes like this. we all know that there r no bears in the southpole.
now consider the middle of the north pole, go straight and u will reach the equator, then take a 90 degree turn east and through the equator walk the same distance, now take another 90 degree north and walk the same distance. u will find urself at the starting point. this will form a triangle with sum of angles >180 degrees = 270 degrees.
this contridction happens due to the spherical nature of the earth. so the bear ends up as a polar bear and its white. what still confuses me is ur mentioning of a specific distance of one kilometer!
you can do the exact same thing pattarkutty without going all the way down to the equator. you can go straight south for 1 km, east for 1 km and then back north for 1 km and end up back at the north pole. the cool part about all this is that there is another solution - that i find to be the trickiest part.
i don't know how u'd reach the same point without reaching the equator. Then it should be possible to draw a triangle with angles 90 degrees with side of any dimension on any part of the sphere. i don't think so...
take my word for it, you don't have to go to the equator :)
think about it purely non mathematically and in terms of cardinal directions for a bit:
imagine starting at the north pole. you go south 1 km, so your distance to the north pole is now 1km (on the sphere). by going directly east or west, that distance doesn't change. so go east, then back one km north again. you arrive at the pole again.
it is possible to draw a triangle that has two right angles even if it doesn't go to the equator. your problem i think is that you want it to have 3 right angles. in that case, i agree, you have to go to the equator. but that's not what the question asks, it doesn't ask you to draw a triangle with 3 right angles in it, it asks you to get back to the same point, i.e. only 2 right angles. try it on a globe, and running your hand from the top (measure it) down 1 cm, around 1 cm and up again. if you measure it, then aside from sic figs you should end up back again. really.
thanks for that. yeah i had 3 90 degrees in mind. and that was not the question.sure u can have 2 right angles anywhere. thanks.
I think there are an infinite number of positions where you can start such a trip, but only one of them is on the north pole, the other ones are on the south pole where there are no bears.
actually you can get an infinite amount of solution, without resorting to south-pole-ness. its all in the topic called mr fubini
