Mathematica What command to be used in Mathematica
  • Thread starter Thread starter kaizen.moto
    Mathematica
The discussion focuses on finding commands in a programming context that yield only determinate outputs, specifically excluding any infinite results. The user seeks a solution for iterations using a Do-loop that currently produces both determinate and indeterminate outputs. Suggestions include using the Select function with NumericQ to filter results or creating a custom function, notInfinityQ, to check for non-infinite values. These approaches aim to ensure that only valid, finite outputs are generated during iterations.
kaizen.moto
Hi,
Iam looking for a specific command(s) that could give outputs which are determinate only, i.e. only and only if the outputs are not infinity.
This is due to the fact that I have iterations cases (using Do-loop) which give both determinate and indeterminate outputs. However, I just wanted to generate the determinate outputs.
Please let me know.
Thank you.
How about Select?
Select[result,NumericQ]
or build a notInfinityQ function that returns True when its argument is not infinity.
