What conditions are needed so that a billiard ball slides rather than rotates?
  • Thread starter Thread starter great_sushi
    Ball Conditions
For a billiard ball to slide rather than rotate, the sliding friction must be overcome by the ball's moment of inertia. The discussion highlights that static friction is responsible for initiating rotation, while a frictionless surface would prevent rotation entirely. It is emphasized that if the frictional force equals the moment of inertia, the ball will not rotate. The conversation also touches on the need for proper dimensional analysis to validate the equations used. Understanding the relationship between torque, friction, and moment of inertia is crucial for determining the ball's motion.
great_sushi
Or at the point at which it starts to rotate...
My thinking is that the sliding friction is the only thing that will cause the ball to rotate F = u*N
N = mg
And moment of inertia I = 2/5*m*r^2
So, when I = 2/5*m*r^2 = u*N = F it will be at the instant of the change over...
Am i right in thinking that??
As far as I know it's the static friction which causes moment and makes the ball roll.
OK static friction. Am I right in equating the two equations?
Well, how did you get it? It doesn't make sense to me.
Well, if the table was frictionless and if you hit the ball dead center it would never rotate...
So the frictional force will be the force that causes the rotation...
The sliding will occur if something opposes the frictional force... ie the mass moment of inertia of the ball.
If the frictional force is equivalent to the mass moment of inertia then the ball won't rotate. Right?
The moment of inertia is a property of an object and it resists angular acceleration cf. mass in linear motion. It is neither a force nor moment. Right? :smile:
OK so I'm wrong. Can you point me in the right direction then?
Take a look at the dimensions (M, L, T, ...). I = ML2, F = MLT-2. So the equation cannot make sense.
What torque does the frictional force exert about the ball's centre?
What kind of movement results from an unopposed torque?
What equation connects that movement with the torque and the moment of inertia?
