Calculating What Date Will it Be in 50,000 Days
  • Thread starter Thread starter rhimmelblau
To calculate a date 50,000 days from now, understanding leap years is essential, as they complicate the calculation. Leap years occur every four years, but century years are exceptions unless divisible by 400. For practical applications, algorithms or built-in functions in software like Excel can simplify the process. Julian Day Numbers (JDN) are often used in these calculations, providing a unique integer for each date. Utilizing these methods will help accurately determine the desired future date.
rhimmelblau
Is there a formula to calculate what date it will be in a certain number of days? I've tried to work this out on my own but don't know what to do with those pesky leap years.
Say you figured out that a comet you want to see will have its closets approach to Earth again in 50,000 days, and you want to mark it on your calendar.
Mathematics news on Phys.org
Just work Mod7 .
You should read the wiki on leap years since it's a little more complicated than just adding a day every 4th year.
Also, are you looking for an algorithm (what calculators would probably use) to find the date, or do you want an actual formula which I'd have to admit would be more complicated?
Looking for a algorithm I could punch into my calculator or include in a piece of code.
Alright well it's not too hard to deal with leap years. Basically, it's a leap year every 4 years, except every century (not including every 400 years).
For the Gregorian calendar, a year is a leap year if it is evenly divisible by 4, except in the case of century years (which end in '00'), which must be evenly divisible by 400. Thus, 2000 was a leap year while 1900 was not and 2100 will not be.
http://en.wikipedia.org/wiki/Gregorian_calendar
This paper describes some algorithms for calendrical calculations:
http://www.cs.tau.ac.il/~nachumd/papers/cc-paper.pdf
Most spreadsheets like Excel include date calculating functions built in. In any event, most of these routines use Julian date calculations, where each date on the calendar has a unique integer, called a Julian Day Number (JDN), associated with it.
http://en.wikipedia.org/wiki/Julian_day
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
11K
