What does î(o) represent in vectors?
Kavya Chopra
This problem is fairly objective (though quite stupid)
What does î(o) represent?
Does it refer to a vector making angle 0 degrees with the x axis?
I searched but couldn't find the answer anywhere. Please help.
Moderator note: post edited and moved from hoemwork
Can you provide some context where you've seen this notation used?
Can you provide some context here? What book or video used this notation?
My guess would be the i represents the unit vector in th x direction and the 0 represents the x component of the vector. Similarly for y using j and z using k.
The notation came initially from quaternion notation. Quaternions were extensions of complex numbers into 3 dimensions. When Gibbs and others decided that quaternion math was useful but overly complicated they extracted out the useful part to make vectors and kept the ijk notation.
Likes scottdave
Did you mean î(o) or ##i^0\,##? And is it an o or a 0?
Î(o). o not 0.
I came across this while I was doing some questions on vectors.
In general, these types of notation need to be defined in the document or book that they appear in. There is no standard meaning of the notation. If the document/book is well done, there will be a summary of notation somewhere. Otherwise, you are forced to scan through the preceding text and try to spot the definition. I always hated the books that required that.
Likes jedishrfu
I see. Thanks a lot.
