thecritic said:
It seems that my question was wrong. (no reply for so long)
What I am basically asking is --> What do direction quantization (of angular momentum) signify? Does it signifiy that
1. there should be only discrete angles between different angular momenta
OR
2. As I said in OP, there should be only discrete angles (greater than \thetamin) between any angular momenta and any chosen arbitrary axis
Hi there,
One of the reasons you're not getting an answer is that in the orthodox interpretation of QM, the answer is 'the question is meaningless since we can never know the reality of a quantum system'.
In other interpretations such as many-worlds people only ever concern themselves with eternal verities and speaking in logically consistent sentences rather than concerning themselves with ontology or 'what really might be going on'. So they're not going to answer you either.
So conventionally one may speak of 'angular momentum' but you have to do 'air quotes' with your fingers as if to say 'but not really'.
In the de Broglie-Bohm interpretation however, the answer is as usual, straightforward. Particles have trajectories, pushed around by an objectively existing wave field represented mathematically by the wave function. And orbital angular momentum really is the angular momentum of particles 'orbiting' the nucleus. Of course this is a bit difficult if you believe that particles only exist when you look at them (as in the orthodox view).
Why is it quantized? You have to remember that in de Broglie-Bohm theory quantities are well-defined and continuously variable for all quantum states - values for the subset of wave functions which are eigenstates of some operator have no
fundamental physical significance. So this characteristic features of QM - the existence of discrete energy levels - is due to the restriction of a basically continuous theory to motion associated with a subclass of eigenfunctions.
Now what happens with angular momentum? Let's say we prepare the system with a wave function which is an eigenfunction of the {\hat L}_z operator (where the direction of the z-axis is arbitrary). Then the z component of the angular momentum will coincide with the eigenvalue of {\hat L}_z, and the total orbital angular momentum with the eigenvalue of {\hat L}^2. Conventionally one would say that the x- and y- components are 'undefined'. However, in de Broglie-Bohm they are perfectly well-defined. In fact you have:
L_x= -m \hbar \cot \theta \cos \theta
L_y = m\hbar \cot \theta \sin \theta
L_z = m\hbar
So the difference is that along the trajectory L_z and the total angular momentum are conserved, but L_x and L_y are not. Thus, although the classical force is central the motion is asymmetrical, which reflects the fact that a particular direction in space has been singled out as the quantization axis.
Hope this helps, though I suspect it won't for some reason.
