What does the sound coming from an open column look like?
The discussion centers on the behavior of sound in an open air column when disrupted, particularly how sound waves interact with the surrounding air. It is noted that the ends of the column act as pressure nodes, with sound traveling as a superposition of standing waves. The sound emitted from the column's ends is described as a diffracted version of these traveling waves, spreading spherically into the surrounding air. The interaction between the resonating column and the outside air is emphasized, highlighting the maximum displacement of air molecules at the open end. Overall, the conversation clarifies the relationship between pressure and displacement in understanding sound propagation from the column.
fiddleback
I believe I understand what happens inside an air column that is open at both ends when you cause a disruption such as blowing into it. But I am not sure what happens in the space between the air column and your ear. Please let me explain what my current understanding is and tell me if I'm wrong.
The ends of the open air column are observed to be pressure nodes and the air around the column has a characteristic speed at which sound travels. When the column is disrupted, the air in the column moves such that the pressure is a superposition of the standing waves that fit onto the column's end nodes (multiples of half-wavelengths). Additionally, each of the component standing waves is equivalent to two traveling waves moving in opposite directions, which can be used to determine the frequency at which each of the standing waves oscillates. Now my guess is that the sound coming out of each end of the column is a diffracted version of the superposition of the traveling waves moving in each direction through the column. Is this correct?
The resonating column interacts with the outside air at the open end (if we idealize that the column walls are rigid).
At the open end, the displacement of air molecules is a maximum - so you have air pushing in and out of the hole, pushing on the air molecules in the "outside" air.
Thus the sound from that end spreads out mostly spherically as a traveling wave.
The inside and outside are coupled systems - what you usually do with a musical wind instrument is make a vibration near it, which gets amplified by the harmonics of the instrument. The whole instrument vibrates the air around it so what someone some distance away hears is the tones and not the initial vibration. The actual wave about an instrument can be quite complicated but the phenomena is not usually called diffraction.
I was thinking in terms of pressure, but thinking in terms of displacement is more intuitive in this case. I see now I'm going to need to pick up another text. But thinking in terms of displacement gives a better sense of how vibrations get pushed towards the listener even if it doesn't give a sense of the waveform that's being sent. Thank you.
You could imagine a flexible membrane over the "open" end of the rigid pipe - then it's going to look like how a speaker works right?
The waveform will be spherical. The amplitude will vary in pace with the end displacement.
And now it is perfectly clear. Thank you for that last remark especially. Cheers.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
