What equation to use for simple kinetics quesitons?
  • Context: High School
  • Thread starter Thread starter Alipepsi
    Kinetics
The discussion focuses on the application of kinematic equations to solve problems involving constant acceleration. Participants recommend using the equations \( v = u + at \) and \( s = ut + \frac{1}{2}at^2 \) for calculating velocity and displacement, respectively. The correct approach involves identifying known variables and selecting the appropriate equation based on the given data. The quadratic formula is suggested for solving time when it appears in both sides of an equation.
  • Understanding of kinematic equations for constant acceleration
  • Familiarity with algebraic manipulation and solving equations
  • Knowledge of basic physics concepts such as velocity, acceleration, and displacement
  • Ability to apply the quadratic formula in problem-solving
  • Study the derivation and application of the kinematic equations
  • Practice solving problems using the quadratic formula in physics contexts
  • Explore examples of motion under constant acceleration to reinforce understanding
  • Learn how to identify which kinematic equation to use based on given variables
Students preparing for physics exams, educators teaching kinematics, and anyone looking to strengthen their understanding of motion under constant acceleration.
Alipepsi
For the questions below, which kinematic equations would I use? I have already tried these on my own but can not find a way to match the answers with the answer sheet, the answers on the answer key are RIGHT, as they are approved by my teacher.
Okey so the questions are
1) A baseball is thrown up vertically at 25m/s. What velocity will the ball have after:
a)1.0s
b)2.0s
c)3.0s
2) A soccer ball is kicked straight up at a speed of 30m/s. How long will it take to reach a height of 5.0m?
It would be great if you showed me how you got your answers, if not, I will really appreciate the equations, THANKS!
Welcome to PF!
Hi Alipepsi! Welcome to PF! :wink:
For both questions, use one of the standard constant acceleration equations.
If you're still stuck, show us what you've tried, and then we'll know how to help! :smile:
Thanks
Tiny, I'am confused =(
I've looked over the equations but can not figure out what equation to use. PLEASE HELP ME I have a test after march break =S
For 1), you have u t and a, and you want v
For 2), you have u s and a, and you want t
So which of the constant acceleration equations has only u t a and v,
and which has only u t a and s ? :smile:
a=vf-vi/t
Then just derive it :P
Yup! :biggrin:
(And the other one? :smile:)​
Vf^2=vi^2+2a(d)
v=sq root 30^2-2(9.81)(5)
v= 28.3m
THEN
Solve for time using the equation: t=(v-vf)/a
answer is 0.17seconds ;D
THANKS FOR YA HELP MAN! :D
You're welcome! :smile:
But quicker would have been s = ut + 1/2 at2 :wink:
I see, can you help me with how to know what equations to use for questions. Like I was confused for what equation to use for the second problem. Do I look for all the values I'am given with the values in all the equatiosn then pick the one? Ik my quesitons is silly :P
I always write down a list of all the given values when I start a problem. Then I compare them to the equations that I know.
So you have to derive for t right?
This is what I got:
t= sq root s-ut/0.5a
This is correct? Really need to know this asap
yes, you'd have to solve for t
did I derive for t correctly there?
you'd have to use the quadratic equation to solve for t in that case.
notice how t= sq root s-ut/0.5a still has a t ion both sides of the equation.
If I was to use quadratic, then how would I get my A, B, and C values from solving that equation?
well the equation is also this:
1/2 at2 + ut - s = 0
so if t is the variable, what are the constants?
You can check for yourself by substituting your formula for t back into the original equation to see if everything cancels out algebraically. Or you can use it to calculate t, then substitute it and your given quantities back into the original equation to see if everything cancels out numerically.
  • · Replies 20 ·
