What force is needed to accelerate a car
To determine the force needed to accelerate a 1200kg vehicle from rest to 108km/hr over 100m, the acceleration and time must be accurately calculated. The final velocity converts to 30 m/s, and using the distance, the time is found to be approximately 3.33 seconds. However, the acceleration calculation is incorrect, as the vehicle does not maintain a constant velocity throughout the distance. The correct approach requires using the average velocity or integrating acceleration over time. The confusion about converting mass to Newtons by multiplying by gravity highlights the need for clarity in applying the force equation.
smarties
What force is needed to make a 1200kg vehicle accelerate from rest to 108km/hr in 100m
aceleration = Velocity/time
Force = Mass x Acceleration
Time = Distance/Velocity
M = 1200kg
D = 100m
V = 108 km/hr / 3.6 = 30 m/s
t = 100m/30 m/s = 3.33sec
a = 30 m/s / 3.33sec = 9 m/s
F = 1200 x 9 m/s = 10800kg
Now do I need to convert the kg to Newtons? by multiplying by gravity 9.8m/s I am a bit confused about that?
Be careful with how you calculated the time of the trip.
You used t=s/v, but that equation is for the case when the acceleration is zero.
The velocity of the car isn't 30m/s for the whole trip, only at the end.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
