Equilibrium of Object Disturbed: What Happens First?
  • Thread starter Thread starter vaishakh
When mechanical equilibrium is disturbed, an object's velocity and acceleration change continuously, complicating the understanding of motion initiation under force. Newton's laws indicate that an object does not move instantaneously, raising questions about the nature of acceleration and higher-order derivatives. In specific cases, such as constant velocity, higher derivatives can be zero, simplifying analysis. The discussion touches on the continuity of speed and the potential singular nature of acceleration during abrupt changes, suggesting that the force's time dependency may not be purely analytic. The conversation also references Penrose's work, emphasizing the complexity of force changes during non-analytic transitions.
vaishakh
When the mechanical equilibrium of an object is disturbed, its velocity, acceleration, rate of change of acceleration and so on everything starts changing continuously. For a change of something the rate of change has to change and the same procedure gets repeated for rate of change. Thus what starts first is doubtful. In short, Newton’s laws cannot explain when does an object at rest start moving when force is applied on it. It only states that the object does not start moving instantaneously.
I think what you're getting at here is that higher orders of position derivatives wrt time would continue infinitely when something is disturbed? Assuming I have the jist of your problem, there are situations in which these higher order derivatives are zero. Take for example, a car traveling at a constant velocity v. We know v is simply the first time derivative of the cars position. If we integrate with respect to time then wes see that s=v*t+c. We can get rid of the arbitrary constant by choosing the coordinates correctly. Now in this example if you want to find the rate of change of velocity you would differentiate twice wrt to time and you will clearly see that the acceleration will be equal to 0.
That was just a simple example but it is very rare that we ever need to use higher order derivatives. The only people i know of that use higher than 3rd derivatives are rolllercoaster engineers. Even then simple laws can be derived by assuming that whatever order derivative is constant. I assume you have seen the equations of motion for constant acceleration.
s=ut+1/2 a*t^2
which you can derive from assuming that d2s/dt2= a constant.
I had the same problem at high school...in my view this problem was : if an object starts moving from rest...does it mean infinite acceleration...but i was told this is wrong...let's take Newton's law : let say if t_-<0\quad t_+ >0 ...then the hypothesis is \ddot{x}(t_-)=0\quad \ddot{x}(t_+)=\delta\neq0\Rightarrow x(t_-)=at+b\quadx(t_+)=\delta/2t^2+dt+e...from the continuity hypothesis of movement : x(0^-)=x(0^+) \Rightarrow e=b this gives that the speed is continuous at t=0...however the accelaration is not, which means the jerk (triple derivative) is Dirac-delta shaped (derivative of a Heaviside step function in this case). However, if the system is taking as being subject to another force (non step-like), then obviously the jerk is not singular...but I don't if there exist a general theory about this...It distrubed me a lot of time indeed... But I think this has to do with the microscopic description of the force acting on the body : deformation and temperature and other thermodynamical concepts have to be taken into account in order to find the right depedence of the force towards time for the "in movement making" out of the equilibrium position.
The error is to think that the only possible time dependencies are analytic functions. Penrose has a nice argument about that in his book "The Road to Reality" (a super read in my opinion!).
Indeed, it is impossible for an analytic function to be 0 over a finite time lapse and then to start doing something from t>t0 onward.
So does this book explain how the Force has to change in a schock similar process...it should be something of the type : F(t)=\left\{\begin{array}{ll} 0 & t<-t_0 \\ e^{-\frac{1}{|t^2-t_0^2|^2} & -t_0<t<0\\ e^{-\frac{1}{t_0^4} & t>0 \end{array}\right.
It is easy to verify that F(t)\in C^\infty(\mathbb{R}) (analytic function different than holomorph)...and F(t<-t_0)=0\quad F(t>t_0)>0...
Can you please send me a copy of the page indicating the rate of change of the force as given in your reference...? We call those Schwarz Function or "compact support dense in L^2 function subset"...if you change slightly with F(t>t0)=0...For remembrance this subset is used in theorem proofs for Fourier transform similar operators properties on separable Hilbert spaces like L^2...aso
The eternal nomenclature. With analytic I meant: can be written in a powerseries around each point in an open domain, with finite convergence radius. Your example function is a C-inf function which is not analytic (I follow the definition that C-inf is "holomorphic" and analytic is series convergence, but I know some authors inverse these terms ; in the complex plane, both concepts are equivalent of course).
The point of analytic functions over R is that a very small segment of them determine the entire function. As such, the small part left of -t0 that is identical to 0 would determine the entire function over R, which would be 0 everywhere. Clearly this is not the case. I think the issue clears out if you continue your function in the complex plane. Then you will see that your smooth function is not at all so smooth.
The entire chapter 9 of "the road to reality" is devoted to this issue (although he does not treat exactly the function you propose). He proposes as "reasonable class of real functions to be used" the difference between a holomorphic function in a part of the upper half plane (down to the real axis) and another holomorphic function in a part of the lower half plane (modulo a holomorphic function over both which will not contribute to the difference of course). Such a "hyperfunction" (an equivalence relation on pairs of holomorphic functions) can then be manipulated by derivation...
(I'm typing this very quickly... may contain some inaccuracies).
cheers,
Patrick.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
