What happens if we heat up the plasma enough?
  • Thread starter Thread starter Prof.gaming
    Heat Plasma
Heating matter transforms it from solid to liquid, then gas, and finally to plasma, which consists of dissociated atomic components. Beyond plasma, increasing temperature can lead to quark-gluon plasma, where quarks are separated from nucleons. However, separating quarks is challenging, as applying extreme force may create more quarks, some of which can annihilate each other. The discussion raises questions about the existence of states beyond quark-gluon plasma, but current understanding suggests it may be the hottest state of matter. The topic highlights the complexities of particle physics and the limits of our knowledge regarding extreme temperatures.
Prof.gaming
I was wondering , because all I know is that we got solid . Heat it up enough and you get liquid . Heat that up enough too and boom ! There's gas . Plasma is another transformation in this category , in this case , about heating up the gas enough . And I wanted to know , if there is anything after that ? Or do we even know if there is or not ?
Science news on Phys.org
Plasma is made up of the parts of atoms - protons, neutrons, and/or electrons - that have been dissociated from each other. If you keep increasing the temperature, eventually you will get a quark-gluon plasma, where the quarks in the nuclei would be separated, except that it's impossible to separate quarks from the nucleus? If you put enough force trying to separate them, I am not sure but I think it makes more quarks, some of which annihilate each other? Anyway, I can't think of anything hotter than a quark-gluon plasma.
Actually, this Fermilab video is pretty good:
Thread 'Thermo Hydrodynamic Effect'
Vídeo: The footage was filmed in real time. The rotor takes advantage of the thermal agitation of the water. The agitation is uniform, so the resultant is zero. When the aluminum cylinders containing frozen water are immersed in the water, about 30% of their surface is in contact with the water, and the rest is thermally insulated by styrofoam. This creates an imbalance in the agitation: the cold side of the water "shrinks," so that the hot side pushes the cylinders toward the cold...
