What Happens to Light Speed When Measured from a Fast-Moving Space Station?
  • #51
Janus said:
Now let's look at the same situation from the frame of the rocket. Length contraction has shortened the distance between the stations, so now the ends of the lines extend past the stations positions when the rocket is at the midpoint. (second image)
Note also that it is the station frame where the length of the line corresponds to the distance between stations. Since the station frame sees the line as length contracted, the rocket frame, in addition to measuring the distance between stations as shorter, also measures the line to be longer.
  • #52
Yep. Exactly so.
  • #53
Janus said:
Maybe the attached images will help.
The situation you describe is extremely interesting, and I find it to be an excellent lesson in length contraction. I haven't had much occasion to think about the length contraction of something large as viewed from something small. I've really only thought about it in terms of Einstein's measuring rods getting shortened. So, by using this example of the ship with filaments you and Plover have gotten me thinking about how, when a ship is traveling at an appreciable fraction of c the very length of the distance it is traveling shrinks from its perspective.
Thank you for putting the graphics together. They, and your verbal description, are quite clear; easy to follow.
However, as I said to Plover when he brought this up, I don't think this particular example can be used to account for why Einstein maintains the observer on his train will see one flash before the other. The reason is that in your example he will not be at point M when the flashes occur, but somewhere else. Einstein is particularly specific in pointing out that the observer on the train will be at point M when the flashes occur: "Let M' be the mid-point of the distance A--->B on the traveling train. Just when the flashes of lightning occur (as judged from the embankment) this point M' naturally coincides with the point M, but it moves toward the right in the diagram with the velocity v of the train."
And if we're in any doubt as to which rest frame Einstein means when he says M' coincides with [/i]M[/i], he makes it specifically clear that he means, at that instant,
in both rest frames:"If an observer sitting at M' in the train did not possesses this velocity, then he would remain permantly at [/M] and the light rays emitted by the flashes of lightning A and B would reach him simultaneously, i.e. they would meet just where he is situated."
In the scenario with the filaments, if the observer at M' "did not possesses this velocity then he would remain permanently at"...some point before M.
The fact the light rays would reach him simultaneously if he did not possesses this velocity should be completely convincing proof that Einstein wants him at M when the lights flash, and then wants him to clear out before the light arrives.
Doc Al asserts that Einstein later concludes this condition cannot be fullfilled. That would be a critical, crucial piece of information for me, but I don't know where to look for it. It isn't in that particular chapter. If Einstein says somewhere that his set up isn't workable, I can stop worrying.
I suggested a means to plover whereby this condition could be fullfilled, to my satisfaction anyway (he hasn't given his reaction) which would be to have a rod sticking out of the side of the train right where the train rider is seated. This rod would make contact with a switch located at point M on the embankment. The switch, when thrown by the rod would send an impulse (of magic, instantaneous energy) to the lights at A and B causing them to flash. In this way, we should be able to be assured that M' is at M when the lights flash.
  • #54
Zoobyshoes the flashes CANNOT occur simulatnously in both rest frames, indeed in the situation described, no flashes will occur whilst the spaceship is at M', it's fairly trivial to prove this.
The problem is essientially one dimeionsal so if we set that the flashes occur at t = 0 and set M as the x = 0 of our co-ordiante system and L the distance from M to the spacesations (in the rest frame of M) then we get the following (x,t) co-ordinates for the situation as described by M as the flashes occur:
M = (0,0) A = (L,0) B = (-L,0)
but in the rest frame of M':
M' = (0,0) A' = (γL,-γβL/c) B' = (-γL,γβL/c)
Therefore the only way that the lights can be emitted simulatenously in bothe refebrce frames is if L = 0 or the relative velocity, u = 0
  • #55
jcsd,
I'm sorry but I can't follow your last post. I think what you might be doing is setting it up with an x,y,z, and a t (for time) coordinate. I am aware this can be done but I have never done it, and can't follow your logic. (I have worked only with x,y,z coordinates.)
If you are trying to demonstrate that the two observers will not agree about when the flash occurred in units of time according a clock one or another has, that I can accept, provisionally.
Likewise, if one catches a glimpse of the others watch he will suppose the others watch is running slow.
What is your assessment of what will happen in the situation where the rod triggers the flash, as I described to plover and Janus?
Incidently, you keep turning it into a pair. It's just one shoe.
  • #56
zoobyshoe said:
jcsd,
The event M is when the spaceship is at the midpoint between the two spacesations I have defined this as happening in the rest frame of M at t =0 and and at point x=0, simlairly I defined the events A and B as the two flashes of light being emitted which also happen at in the rest frame of M at t = 0 (i.e. in this rest frame all 3 events are simultaneous) and at x = L and x = -L respectively.
I then applied a Lorentz transformation to find out what is happening in the rest frame of the spaceship and arrived at the above co-ordinates telling be that none of the evnts are simultaneous in this rest frame (γ and β are 1/√(1 - u^2/c^2) and u/c respectively where u is the relative velocity of the spaceship.[/quote]
Yep that's what I'm trying to show, but remember , assuming all clocks are 100% accuarte, no clock is better than any other clock, so both are objectively measuring the 'real distance' in time between the events.
It's pretty much the same situation as the events will still have the same spacetime coordinates
I'll try to remember.
  • #57
OK, I follow this.
I think I follow this. Let me check. You are saying you have shifted your perspective to that of the ship and applied the Lorentz transformation to find out what the observer on the ship will say about the timing of the flashes?
I recognise a Lorentz transformation in all this Greek. Don't know what &gamma and &beta, mean. "&radic" looks like it must mean "square root".
The results you gave earlier:
M = (0,0) A = (L,O) B = (-L,O)
M' = (0,0) A' = (?L, -??L/c) B'= (-?L, ??L/c)
show there is a difference, but I need a bit of an explanation. The parentheses each contain two coordinates. For M and M' are these x and t, respectively? For A and A', and B and B' these are length and time respectively? Also, I don't understand the signifigance of the question marks in the parentheses.
OK, you made a point of saying this, so I know it's important to your explanation, but I'm not sure what the phrase "`real distance´ in time" means. I´d appreciate it if you would expand a bit so I don´t miss the signifigance.
  • #58
Right. Note that Einstein explicitly says "as judged from the embankment".
And if we're in any doubt as to which rest frame Einstein means when he says M' coincides with M, he makes it specifically clear that he means, at that instant,
in both rest frames:"If an observer sitting at M' in the train did not possesses this velocity, then he would remain permantly at M and the light rays emitted by the flashes of lightning A and B would reach him simultaneously, i.e. they would meet just where he is situated."
There is no question that M' passes M at the the exact moment that the lights flashed according to the M-frame observers. Of course, both frames agree that the coincidence of M and M' happens "at the same instant". How could it be otherwise?
Right. M' passes M just as the lights flash according to the M frame.
Perhaps I wasn't clear. What I thought you were saying is that M' and M must coincide at the exact moment that the flashes are emitted according to both frames. This is, of course, impossible. (After all, as Einstein shows, the M' observers do not agree that the lights flashed at the same time.) All Einstein requires is that M' pass M just when the embankment frame says the lights flash.
I assume you are joking. If we start allowing magic, instantaneous messaging between the midpoint and the lights at A and B, then we have left the realm of physics. The way to set it up is as I already described. Three clocks (at A, M, and B) in the embankment frame, synchronized. Prearrange that when the clocks strike a certain time (say 12 noon) the lights will flash. Just have M' pass M exactly when the clock at M reads 12 noon.
  • #59
zoobyshoe said:
OK, I follow this.
Yep.
That is odd, you should be able to see the html chartacters: here it is again in latex (also it's a zero not an 'O'):
M = (0,0)
A = (L,0)
B = (-L,0)
M' = (0,0)
A' = (\gamma L,\frac{-\gamma\beta L}{c})
B' = (-\gamma L,\frac{\gamma\beta L}{c})
Where:
\beta = \frac{u}{c}
\gamma = \frac{1}{\sqrt{1 - \beta^2}}
Where u is the relative velcoity of the spaceship to the space station
What I've done is basically create a co-ordinate susyetm the co-ordinates for each event are (x,t) where x is the distance from the midpoint of the space station (i.e. x = 0 at M) and t is the difference in time from when the spaceship and M occupy the same spot (i.e. t = 0 as the spaceship arrives at M)
The significance is that both distance and time are not absolute.
  • #60
I hope you realize that introducing a method of instantaneous transmission violates the very principles we are trying to clarify. The best we could do is place such rods an equal distance ahead of and behind the train rider, space so that when form the rider's perspctive, these rods trigger switches at the stations themselves which initiate the the flashes at each station.
This just gives us the reverse situation as we had in the last set of images I made.
This time, from the embankment frame, the ends where the poles don't even reach to the stations when the ship is at the midpoint. (image 2)
So the sequence from the embankment would go like this:
First the trailing station is switched on (third image) and then the leading station is triggered (fourth image).
Thus taking both this and the earlier attachment into account, one sees that the stations can either flash simultaneously in the station frame and not so in the train frame, or they can flash simultaneously in the train frame, but not in the station frame. But they cannot flash simultaneously in both frames. (assuming that each staion is only triggered once)
  • #61
This was a really interesting article to read!
May I ask if the same thing would occur if someone threw a ball (traveling 299,999.99 km per second) at the ship instead of sending a light beam towards it? If the ship was 299,999.99 km away from the station and the ship was moving away from the station at 150,000 km per second, (or the station was moving away from the ship at 150,000 km per second) would the ball take 1 second to reach the ship (relative to the observer on the ship) or would it take well over one second?
  • #62
Same thing. It would take about 1 second (according to observers on the ship) for the ball to reach the ship, assuming that the speed of the ball is 299,999.99 km/s with respect to the ship and that the distance of 299,999.99 km is as measured by the ship. (We'll ignore any difficulties involved in actually throwing a ball with that speed.)
Even if that speed was the speed of the ball with respect to the space station, it would turn out that the speed as seen by the ship would still be pretty close to c. (See relativistic addition of velocities.)
  • #63
Noted.
Super!
What I am saying is that there is an instant when M' and M coincide in time and location, and they would both agree such an instant existed. (This, I believe, is how jcsd has set up his coordinate system. M = (0,0) and M' = (0,0) ).
In the M frame (embankment) the flashes of light are emitted at t=0.
However, at t=0 neither M nor M' knows the light has been emitted. Only Einstein and we know that.
Your clocks will do wonderfully, thanks.
  • #64
Ok. This is much better. Thank you for translating it to LaTex.
Clear. I will plug the .5 c into these and try to make sure I understand what they are saying. Thanks.
  • #65
At some point in the future I might like to start a thread exploring what criteria must be met by a given suggested gedanken fiction for it to be acceptable. That is moot now since I don't need it any more. Doc Al's three clocks, and 12 noon stipulation work fine.
  • #66
zoobyshoe said:
Good to have you here.
Thanks.
(You got to love a place where you can get respect for waxing excruciatingly pedantic on a passage from Einstein... :biggrin: )
Note on the following:
For the sake of syntactic (and my own) sanity, I'll refer to [post=251281]my prior post[/post] analyzing the Einstein passage as EP (for Einstein Post). I've added section numbers to it, and the notation EP(n) indicates section n of the post.
zoobyshoe said:
You have pointed out that the observer on the embankment will suppose the observer on the train sees one flash before the other. However, there is doubt in my mind as to whether you think Einstein is asserting that the man on the train will see one flash of light before the other in his reference frame on the train.
The short answer: yes, I do think Einstein is asserting that. (I can also agree that the degree to which EP(7) makes that explicit is less than absolute. :smile:)
zoobyshoe said:
His wording is iffy at many points,
I agree, it has its ambiguous spots. It would be good if we could know whether it was Einstein or the translator who is responsible for that. Unfortunately, I don't know German. Anyone out there want to comment on the translation of Ch 9 of Einstein's book?
zoobyshoe said:
but since he comes to the conclusion "Events which are simultaneous with reference to the embankment are not simultaneous with respect to thr train, and vice versa (relativity of simultaneity)." it seems unbelievable to me that he could only be talking about what the observer on the embankment thinks the observer on the train might be experiencing.
Einstein is making a much stronger statement than this. The underlying logic of the argument for the paragraph analyzed in EP is (as I read it):
Given the rigorous way in which the circumstances have been defined, what conclusions must an observer on the embankment at M deduce about the experience of an observer on the train at M'?​
(The conclusion in this case being, of course, the sentence you just quoted: "Events which ... (relativity of simultaneity).")
zoobyshoe said:
I'm not claiming Einstein's argument is false.
I did not really expect that you were. But given the number of threads around here called "Special Relativity Must Die" or some such, I thought it best to make completely sure... :smile:
zoobyshoe said:
I don't object to length contraction or time dilation being brought in if it can be used to explain that the observer on the train will see one flash of light before the other.
This is not the impression I received from your comments in [post=250589]post #41[/post]. Thus the method of EP was to try to use only the premises that Einstein used up through Ch 9 to make the argument. While Einstein doesn't say anything that conflicts with relativity, he does introduce common sense notions and later discards them when they are no longer tenable in the framework he is unfolding, and this might lead to points where certain types of comparisons become muddy.
zoobyshoe said:
I've reread your explanation of the reason the observer on the train might see one flash before the other.
Which one are you referring to? The train version in [post=249898]post #25[/post] of the thread, or the rocket/filament one in [post=250351]post #39[/post]? (The arguments in these are the same but the context might affect something.)
zoobyshoe said:
[It] is dependent on point M of the track and point M' of the train not actually corresponding when the light flashes for it to work.
How so?
zoobyshoe said:
That would be fine except Einstein is, it seems to me, explicit about the fact that point M' of the train must correspond to point M of the embankment when the flashes occur.
EP(4) addresses this.
zoobyshoe said:
(I don't know why he even bothers to mention what the ends of the train are doing when he is so exacting in his description of the midpoints lining up.)
I suspect that one reason that Einstein chooses a train as the vehicle (no pun inten... oh, who am I kidding?) for his argument is that, as an object that both moves and extends a considerable distance along the line of its motion, it corresponds well to an entire axis of a second reference frame, and thus makes the idea of a moving system of coordinates less abstract than would a moving object that functions in a more point-like way in the imagination.
As the quote preceding EP(1) shows (and Ch 8 goes over in more detail), the point M is not determined a priori but is constructed as part of the mechanism for determining the simultaneity of the flashes at A and B. Similarly, the points A' and B' are used to fix the point M'.
Note that A' and B' are defined in reference to the embankment frame. A' is the point in the train frame that happens to coincide with A when the flash takes place at A. B' is defined similarly.
zoobyshoe said:
It seems to me he is trying very hard to describe a situation exactly like what would happen if a rod sticking out from the outside of the train beside the observer on the train were to trip a switch located at point M on the embankment causing the flashes (the signal getting from the switch to the lights instantaneously, by magic, of course). Does that not seem to be the case to you?
As Einstein sets up this example, the point M as I pointed out above, is determined by the points A and B. So if anything it is like the flashes cause someone to be magically teleported to M (ploink!) in order to determine whether or not they were simultaneous.
In the interest of annoying or appeasing everyone evenly (as the case may work itself out), I will suggest that it was injudicious to introduce magical phenomena into a physics discussion that is treating the foundation of relativistic time effects, and which currently seems to turn on the confusion caused by minute differences in definition of terms (and especially when the phenomena introduced are not accompanied by appropriate sound effects); and on the other hand, I will also suggest that commenters could cut some slack for the use of what was essentially (and syntactically marked as) a rhetorical device, and one which, by its own rules (and considered as an "as if"), is not technically incorrect.
(Continued in next post - broken up due to length restriction.)
  • #67
(Continued from previous post.)
This is an example of why I think that the answers from early in this thread (while correct) may be misleading if introduced to this stage of Einstein's argument.
One thing that needs to be agreed upon is the purpose of Ch 9. I have stated in a couple of places (in slightly different terms) that I believe that the intent is to show what may be deduced about the perception in the train reference frame of events determined to be simultaneous in the embankment frame.
The emphasis of this needs to be changed slightly however: the perceptions that are being examined in the train reference frame are restricted to temporal perceptions. Thus, while a fully worked out framework for Special Relativity offers the result, there is no mention made, or circumstances implied as to spatial relationships as perceived in the train reference frame.
There are several spatial relationships established over the course of the passage, but each is described from the embankment frame. These are (see also EP(4)):
  • A' coincides with A at the moment of the flashes.
  • B' coincides with B at the moment of the flashes.
  • M' coincides with M at the moment of the flashes.
  • M' is somewhere to the right of M at the moment it passes the flash from B, and somewhere further to the right when the flash from A passes it.
As noted in EP(4) the only frame for which "the moment of the flashes" is defined is the embankment frame. Indeed the conclusion of the argument is that the phrase "the moment of the flashes" turns out to be nonsensical in the train frame.
To make the complaint that an observer at M' "will not be at point M when the flashes occur" is to anticipate the argument by using an assumption about time in the train frame as a premise rather than a conclusion.
zoobyshoe said:
And if we're in any doubt as to which rest frame Einstein means when he says M' coincides with [/i]M[/i], he makes it specifically clear that he means, at that instant, in both rest frames:"If an observer sitting at M' in the train did not possesses this velocity, then he would remain permantly at [/M] and the light rays emitted by the flashes of lightning A and B would reach him simultaneously, i.e. they would meet just where he is situated."
There is a moment when M and M' coincide.
In each reference frame it happens at the particular moment when the two points coincide (however that moment is defined by clocks located in the respective frames).
The two points do not continue to coincide because they are in different frames.
In the embankment frame, that moment also happens to be the one when the flashes occur. There is nothing in the sentence you quote that warrants saying anything about the flashes in the train reference frame. The path of the argument is, in fact, to lead you to the conclusion that our knowledge about the flashes in the embankment frame forces the conclusion that they will not be considered simultaneous in the train frame.
At this stage of the argument, there is no point where the position of the observer at M' can be defined - as considered from the train reference frame - when either flash occurs.
The only point under consideration is whether our knowledge of the simultaneity of the flashes in the embankment reference frame allows us to maintain that they will also be simultaneous in the train reference frame. And of course, as it turns out, we may not maintain that.
I find this and the points following it rather confusing. Perhaps you could restate them in terms of my comments above. (Some point "before" M? While such must have occurred, it is not mentioned anywhere in the argument.)
  • #68
Plover,
We are definitely at odds about what Einstein has set up in terms of where M' is when the flashes occur, whose perspective is the one he wants us to be aware of in any given sentence, and the function of A' and B' of the train.
Consider the first sentence of the chapter:
"Up to now our considerations have been referred to a particular body of reference, which we have styled a "railway embankment".
By "our considerations" he means his own and his reader's.
He goes on from here to "refer" his and his readers considerations from the view of someone on the railway embankment to that of someone on the train. From this point on, we are in the train frame of reference, except where otherwise noted.
There is no double imagining going on: we are not imagining ourselves to be in the frame of the embankment imagining the frame of the train. We are in one or the other, according to where he asks us to be, but never in one imagining the other.
Also: he never says that A' and B' "coincide" with events A and B. He uses the word "correspond":
"But the events A and B also correspond to positions A and B on the train. Let M' be the mid-point of the distance A---->B. Just when the flashes (footnote: As judged from the embankment) of lightning occur, this point M' naturally coincides with the point M..."
And he uses the word "coincides" when speaking of the relationship of M to M'. So, "correspond" and "coincide" are not describing the same thing, although I am not at all certain what relationship he means to imply when he uses "correspond". This is where he is "iffy".
This sentence is explicit and crucial:
"If an observer sitting in the position M' of the train did not posses this velocity, then he would remain permanently at M', and the light rays emitted by the flashes of lightning A and B would reach him simultaneously, i.e. they would meet just where he is situated."
That sentence refers to the reference frame of the train. Einstein is speaking to us concerning a point he wants us to understand about the reference frame of the train.
The couple times he deviates from the reference frame of the train are specified: once with the words in parentheses "(considered with reference to the railway embankment)" and another time with a footnote.
  • #69
jcsd said:
\beta = \frac{u}{c}
Because I am a math and latex basket case you will, I am sure, be a sport and not make viscious fun of me for approaching this "trivial" problem at a ponderously slow pace.
For \beta I get: .5
u = .5 c = 150,000 km/s
\beta = \frac{u}{c} therefore \beta = 150,000/300,000 = .5
For \gamma I get: 1.1543958
.52 = .25
1- .25 = .75
\sqrt{.75} = .8660254
1/.8660254 = 1.1547005 = \gamma
So, before I proceed, would you be kind enough to glance at this and make sure I've gotten this far correctly using .5c as the ships speed.
Thanks
  • #70
Looks good to me.
  • #71
OK. My next step, I believe, should be to look at the distance L. In the inertial frame of the station the distance L = 300,000 km. It will not be the same distance to the ship by virtue of the ships speed. To the ship the length L will be contracted. The ship will find L to measure something less than 300,000 km.
jcsd has provided the formula \gamma L to use to determine what the ship will find L to be from its perspective.
He has provided this formula:
to describe "gamma"(\gamma).
The value I got when I solved for gamma earlier using .5 c for the relative velocity of the ship and the station was
1.1547005.
1.1547005 times 300,000 = 346,410.15 km
346,410.15 km > 300,000, not < 300,000.
Instead of contracting, the length has dilated!
jcsd has given us the wrong formula. He has given us the formula for time dilation, not length contraction.
The formula for length contraction is simply:
\sqrt {1 - \frac {v^2}{c^2}}
the result is the percentage of the length that the observer will see that length contracted to.
In our example, the ship will see the 300,000 km to have contracted to .8660254 % of its original length.
That comes out to be 300,000 times .8660254 = 259,807.62 km.
  • #72
Actually jcsd is correct.
When he writes
M=(0,0)
A=(L,0)
B=(-L,0)
He is stating that the distance to either A or B from M is L and thus each half of the train measured in the embankment frame is also length L (so total length 2L). However, the train is moving in the embankment frame and thus appears contracted.
So the rest length of each half of the train, i.e. the length measured in the train reference frame is indeed \gamma L (an un-contraction, if you will). This is the first value you calculated (~346k).
However, in the train reference frame the track is moving and thus the distance from M to A appears contracted. This length is usually expressed as \frac{L}{\gamma}. This is the second value you calculated (~260k).
  • #73
Two comments:
(1) Unless I haven't been paying close enough attention, it looks like you have changed the scenario a bit from your original one. I thought that your original scenario had the distance = 300,000 km as measured in the rocket frame, not the station frame. But to get a close analogy to Einstein's train problem, you should have the distance measured in the station frame. That way the station frame corresponds to the embankment frame. (But realize the answer to your original question will be different now.)
(2) Yes, if the distance is L in the station frame, the rocket will measure that distance to be shorter.​
I believe you are misinterpreting what jcsd provided. jcsd analyzed the Einstein train example from both the embankment and the train frames. He gave the space-time coordinates of three events: A (the light flash at A), M (the passing of M' by M), and B (the light flash at B). So, when jcsd gave these equations:
M = (0,0)
A = (L,0)
B = (-L,0)​
he was giving the location and time coordinates of these events according to the embankment frame. Thus the three events happen at the same time (T=0) and A and B happen at positions -L and +L from the midpoint.
When he gave these equations:
M\&#039;\; = (0,0)
A\&#039;\; = (\gamma L,\frac{-\gamma\beta L}{c})
B\&#039;\; = (-\gamma L,\frac{\gamma\beta L}{c})​
he was providing the location and time coordinates of these same events, but according to the train frame. Note that the times are different.
\gamma L is not the distance L as measured by the train! It is the position coordinate of an event.
  • #74
Doc Al said:
Two comments:
(1) Unless I haven't been paying close enough attention, it looks like you have changed the scenario a bit from your original one. I thought that your original scenario had the distance = 300,000 km as measured in the rocket frame, not the station frame.​
If the rocket measures it to be 300,000 km in its own frame, the station will also measure it to be 300,000 in its own frame. Each will measure it to be shorter in the other's frame, however.
Kinda goes without saying.
He says: "x is the distance from...", so, the L given by jcsd represents the lengths M--->A and M---B respectively.
M = (0,0)
A = (L,0)
B = (-L,0)​
I would buy what you say about -L and +L as positions, except you can't apply a Lorentz transformation to a point. A point has no dimensions.
M\&#039;\; = (0,0)
Yes, I noticed that the second term in the parentheses for A' and B' were different. I found that mighty peculiar also, since no time has passed yet. We are still at T=0 for both reference frames.
Whatever it is, he tried to apply the Lorentz tranformation for time dilation to it. There's no good reason to do that to a length or a point in a coordinate system.​
  • #75
When he writes
M=(0,0)
A=(L,0)
B=(-L,0)
Sophist.
Any length that one observer measures to be contracted will be its original length when "uncontracted, not greater than its original length.
  • #76
Below is an excerpt (Chapter 12) from my upcoming book, "Space, Time and Elementary Particles. (Proof in chapers 13 and 14, not attached)
Chapter 12 The Speed of Light and Space-Time
c = d / [(t2-t0) / 2]
The speed of light is measured with the Fizoau procedure (for Armand Hippolyte Louis Fizoau (1819-1896) a French physicist who, as one of his many accomplishments, was the first to measure accurately the velocity of light (on Earth) in 1849. The following is a description of the Fizoau procedure.
Definition: The speed of light is the speed of propagation of electromagnetic waves in a vacuum, which is a physical constant equal to exactly 299 792.458 km/s.
McGraw-Hill Dictionary of Scientific & Technical Terms
The Fizoau procedure takes a beam of light, bounces it off a mirror a measured distance away and then divides that distance by one-half of the measured time for the round trip: d / [(t2 - t0) / 2]. A photon is emitted from RSX at time t0 toward the mirror M that reflects the photon at time t1. RSX sees the photon at time t2. Since the speed of light is a constant, the two world lines of the photon (RSXt0 to Mt1 and Mt1 to RSXt2) are equal.
Fizoau set up an apparatus, which consisted of a rapidly spinning wheel with tooth gaps evenly spaced around the edge of the wheel. At a point (RSX), Fizoau directed a beam of light through the gaps at the edge of the rapidly rotating wheel towards a mirror eight kilometers away. The speed of the wheel was adjusted until the returning light could be seen through the next gap. Fizoau, by measuring exactly how fast the wheel was turning, could calculate an exact time for one gap on the edge of the wheel to be replaced at a specific location by the next gap around the edge of the wheel. After taking many readings, Fizoau calculated the speed of light to be 315,000 kilometers per second. Leon Foucault improved on that measurement a year later by using rotating mirrors and attained a speed of 298,000 kilometers per second. Foucault’s technique was accurate enough to confirm that light travels slower in water than in air.
Different forms of Fizoau’s experiment have been carried out many times over the years with a longer or shorter distance d, using a different frequency of photon, at different locations on the earth, at different times of day, with different positions for the apparatus and with different reference systems in motion relative to each other. The answer is always 299,792.458 kilometers per second exactly (in a vacuum). The speed of light is a constant for all observers that are in motion with a constant velocity.
The speed of light is an exact measurement: 299,792,458 meters per second exactly (in a vacuum) but that exactness is not by accident. Galileo has been credited with being the first scientist to try to measure the speed of light. Galileo used a lamp that he could uncover and when his assistant, at some distance away, saw the light from Galileo’s lamp, the assistant uncovered his own lamp. By knowing the distance between himself and his assistant and by measuring the elapsed time (Galileo had to use a clepsydra, a water clock, to measure the time interval) until he saw his assistant’s lamp, Galileo tried to calculate the speed of the light beams. Galileo concluded that if light is not “instantaneous, it is extraordinarily rapid.” This was in 1667 and Galileo figured that the speed of light was at least ten times faster than the speed of sound. (Actually, the speed of light is almost nine-hundred thousand times faster than the speed of sound.)
In 1675, the Danish astronomer Ole Roemer measured the speed of light. The astronomer noticed that the eclipses of the moons of Jupiter changed with the relative positions of Jupiter and Earth. When Earth was closer to Jupiter, the eclipses happened sooner than when Jupiter was far from Earth. The time difference between when the moons of Jupiter were expected to eclipse and when they did eclipse was up to sixteen minutes. Roemer reasoned that the change was caused by the greater distance that light had to travel when Earth was farther from Jupiter. Using the then accepted distances between the orbits, he calculated that the speed of light to be 225,000 kilometers per second.
After Fizoau made his measurement in 1849, Foucault and other experimenters began measuring the speed of light with greater precision. As the speed of light was measured with increased precision, the definition of a meter and of a second had to be defined with greater precision.
Historically, the meter was defined by the French Academy of Sciences as 1/10,000,000 of the distance from Earth’s North Pole to the equator on a line that ran through the city of Paris. This definition was replaced 1874 and refined in 1889 by an exact measurement between two marks on a bar of 90% platinum/10 % iridium that was kept in a vault in Paris. Then in 1960, the meter was re-defined as 1,650,763.73 wavelengths of the emissions of the gas Krypton. In 1983, a meter was re-defined again as the distance that light travels in a vacuum in 1/299,792,458th of a second. Then, to define a second, there had to be very accurate clocks. In 1955, the first atomic clock was built and refined in 1958. 1967, the 13th General Conference on Weights and Measures first defined the International System (SI) and a second was defined by 9,192,631,770 periods of the radiation of the cesium-133 atom. These clocks provide an accuracy of 2 nanoseconds per day or one second in 1,400,000 years.
The meter went from being defined as a distance in space (1/10,000,000 of the distance from the North Pole to the equator) to being defined as a measure of time (1/299,792,458th of a second) which can be equated, with the speed of light, into a distance in space.
c = d / [(t2-t0) / 2] When t2 – t0 is 2/299,792,458 seconds, d is defined as 1 meter.
The exact length of a meter is a fraction of space-time.
By international standards, a second is defined as the duration of 9,192,631,770 periods of the radiation corresponding to the transition between two hyperfine levels of the ground state of the cesium-133 atom.
Over a distance in time of one meter, the radiation of the cesium-133 atom oscillates 30.663319 times (1/299,792,458 of a second, times 9,192,631,770 Hz/sec. = 30.663319 Hz).
The oscillation of one wavelength equates to a distance of 1.087827757*10-10 seconds on Tk.
Or, one wavelength as measured as a metric distance on Tk is 3.261225571 centimeters.
Measuring Time in Units of Distance
Minkowski described the space-time continuum as an inseperate union and he used the complex configuration (√-1) for time measurement to allow time to be considered as the forth dimension equal to the three spatial dimensions: (ds)2 = x2 + y2 + z2 + tk2. However, space and time are measured in different units. By international convention, the units that are used around the world for scientific discussion are standardized: the meter/kilogram/second standard is used to measure length, mass and time. However, for any unit of distance that is chosen to measure space, a corresponding unit of distance can be used to measured time.
Thus, to change seconds into meters, the time interval in seconds is multiplied by the speed of light measured in meters per second.
c = 299,792,458 meters per second.
▲t = 1 second. c * ▲t = 299,792,458 m/s * 1 second. Then ▲t equals 299,792,458 meters.
▲t = 1/299,792,458th of a second.
c * ▲t = 299,792,458 m/s * 1/299 792 458 second. Then ▲t equals 1 meter.
When t is measured in seconds, a formula to measure a distance, ds, in space-time may be written as ds2 = x2 + y2 + z2 + c2t2 and the time interval conversion is positioned in the formula. In a space-time diagram, when using equal scales of space and time, one unit of space equaling one unit of time, the time units are directly convertible into spatial units. When one unit on the spatial axes is measured as one meter, then ▲t is equal to one meter on the Tk axis (time axis in the forth dimension). Whatever units the speed of light is measured in; meters, miles or cubits, the forth dimension can be measured in exactly the same units.
When ▲t on Tk, is measured as one second, then the passage of space through time, N to N+1sec., has progressed through 299,792.458 kilometers of the forth-dimension.
https://www.physicsforums.com/attachment.php?attachmentid=1165&stc=1
With distance in the forth dimension measured the same as distance is measured in space, a time interval that is measured as one second is equal to 299,792.458 kilometers on Tk. The corollary is that three-dimensional space, N, progresses to N+▲t through the forth-dimension at 299,792.458 km per second measured on Tk. Space, all of space, is physically moving through the forth dimension of time. The speed of light reflects the velocity of space through the forth dimension. Any observer in any reference system is measuring the velocity of N as N progresses to N+▲t when they measure the speed of light.
Space travels through the forth dimension in one direction. This forward direction creates the progression of our existence from the present to the future. As three-dimensional space progresses through the forth dimension from N to N+299 792 458 m, the clocks in RSS (Reference System Space)register one second. Other reference systems that have a velocity reference to RSS will measure space and time differently than RSS (the Lorentz transformations), but every reference system that maintains a continuous existence in space progresses through time with RSS into the future in N to N+▲t.
  • #77
Eyesaw said:
Nay, I think what we are all amazed at is the fact that the moving observer will be gullible enough to think receiving the signal at a different time than the stationary observer is equivalent to the source emitting the signal at a different time.
The observer on the train is meant to be ignorant of the actual timing of the flashes: he doesn't know when the man at the mid point receives them. All we want to know from him is: "Did you see them at the same time, or one before the other?"
The question, more or less, that Einstein has posed in a previous chapter is "When something seems simultaneous, how do we know if it really is or not?" (Not an exact quote, just a characterization.) He is pointing out in this chapter that you can't tell from the relative timing of the arrival of the flashes, if they were emitted simultaneously in their own rest frame.
  • #78
So now you have two lengths? One is 300,000 km measured by the rocket? And the other is 300,000 km measured by the station? What are these two lengths? They aren't the same thing, obviously.
I would have thought... but here we are.
L is the distance between A and M, and B and M, measured in the embankment frame.
Lorentz transformations are used to convert space-time coordinates of an event (a point in space time) from one frame's measurements to another's.
You are missing the entire point. The events (1) Light A flashes and (2) Light B flashes do not occur at the same time according to the train frame!
I suggest that you learn a bit about the Lorentz transformation. :smile:
  • #79
Eyesaw said:
If A' coincides with A at the moment of the flashes and B coincides with B' at the moment of the flashes and M' coincides with M at the moment of the flashes, how can "the moment of the flashes" be different for either the designated stationary or moving observer? That's like saying given 1=1 and 2=2 and 3 = 3 and 4 = 4, 1 is not 1 and 2 is not 2 and 3 is not 3 and 4 is not 4.
While A' (a point on the train) coincides with A (a point on the embankment) at the moment that A flashes, this does not mean that the train clock at A' agrees with the embankment clock at A. In fact, they obviously don't.
Obviously the the events are absolute in time and place for both inertial observers and the relative simultaneity being argued in that booklet is that of the arrival time of the light reflected from the events.
If that's what you think, then you'd better read it over. The two frames disagree as to when the flashes occured, not just when the light is detected by the observers.
  • #80
I don't quite understand this are you saying the moment when A coincide with A' coincide with A flash are not simultaneous because someone on the embankment is wearing a watch synchronized with the time in Bei Jing while the gal on the train is keeping the time in France?
  • #81
:smile: Good one, Eyesaw.
When A and A' coincide is a single event in space-time (something that happens at particular place and time). But the time that this event occurs will be measured differently in different frames.
The issue for simultaneity is not: Do A and A' pass each other at "the same instant"? Of course they do! The issue is: does the passing of A and A' happen at the same time as the passing of B and B'? And this question is answered differently in different frames: these two events are observed to happen at different times in the train frame.
  • #82
This post started out as a simple comment on the last sentence of thread post #73 by Doc Al. The actual result is more of a digression on some of the formal aspects of Special Relativity that, in the context of this discussion, either have only been sketched or have been described piecemeal.
I agree with what you say here, but as stated (and presuming it is meant as a warning about my previous post [#72]), it may obscure what is correct and what might be misleading about my post.
1) (To clarify for readers unfamiliar with the terminology)
Event is the term used for a given point in the mathematical space used to describe relativity. Specifying an event requires both space coordinate(s) and a time coordinate. The definition covering the current situation, as given by jcsd, is:
"What I've done is basically create a co-ordinate susyetm the co-ordinates for each event are (x,t) where x is the distance from the midpoint of the space station (i.e. x = 0 at M) and t is the difference in time from when the spaceship and M occupy the same spot (i.e. t = 0 as the spaceship arrives at M)."
Each reference frame describes the same set of events. However, different reference frames overlay different systems of coordinates onto these. The differing measurements determined by these different coordinate systems reflect the space and time distortions that occur when measurements are made in different reference frames.
2) The Lorentz transformation is the mathematical operation that maps the coordinates of events in one reference frame to the coordinates in a second frame.
The ordinary Lorentz transformation maps event coordinates in the rest frame to event coordinates in some other inertial frame.
If an event has coordinates (x, t) in the rest frame, then the general transform \Lambda to coordinates (x', t') in a frame with relative velocity u is:
(x&#039;, t&#039;) = \Lambda (x, t) = \left( \gamma (x - ut), \gamma(t - \frac{ux}{c^2}) \right)​
If, however, what is known is the coordinates (x', t') in the moving frame, then to find the coordinates (x, t) in the rest frame what is required is the inverse Lorentz transformation \Lambda^{-1}. This has the general form:
(x, t) = \Lambda^{-1} (x&#039;, t&#039;) = \left( \gamma (x&#039; + ut&#039;), \gamma(t&#039; + \frac{ux&#039;}{c^2}) \right)​
3) Ok, I screwed up. I just realized that jcsd was talking about the spaceship scenario not the train scenario, so the way my previous post (#72) compares what I say to what jcsd said makes no sense, and I should probably edit it. (Without the comparison, the logic still holds - though with the caveats given below.)
4) Just to be clear: I'm discussing the train scenario.
In the embankment frame, coordinates are denoted:
(x_m, t_m)​
where xm is a spatial coordinate along an axis defined by the track, and tm is a time coordinate.
For any time tm in the embankment frame, the observer M has coordinates:
M(t_m) = (x_M, t_M) = (0, t_m)​
We also have two events - flash at A, and flash at B - that happen at tm = 0. Coordinates for these are:
\textrm{flash}_A = (x_A, t_A) = (-L, 0)
\textrm{flash}_B = (x_B, t_B) = (L, 0)​
(I've switched the signs so that the train moves toward positive xm.)
The flashes occur at the same moment that the rear and front of the train pass (respectively) A and B. In other words, in the embankment frame the length of the train equals the distance from A to B.
In the train frame, coordinates are denoted:
(x_{m&#039;}, t_{m&#039;})​
The axis along which the spatial coordinate xm' is measured is defined by the track and thus coincides with spatial axis used in the embankment frame (it's coordinate system, however, is, of course, separate).
For any time tm' in the train frame, the observer M' has coordinates:
M&#039;(t_{m&#039;}) = (x_{M&#039;}, t_{M&#039;}) = (0, t_{m&#039;})​
The coordinates of flashA and flashB transformed into the train frame (as given by jcsd, but with signs reversed) are:
\textrm{flash}_{A&#039;} = (x_{A&#039;}, t_{A&#039;}) = (- \gamma L, \frac{\gamma\beta L}{c})
\textrm{flash}_{B&#039;} = (x_{B&#039;}, t_{B&#039;}) = (\gamma L, \frac{-\gamma\beta L}{c})​
This is an example of the inverse Lorentz transformation as defined in item 2) above. (We consider the train to be at rest so we are going from a moving frame to a rest frame.) Calculating using the formula from item 2) we get:
This has been corrected. See post #99 below for the reasoning behind the use of -u.
<br /> \begin{equation*} \begin{split}<br /> (x_{A&#039;}, t_{A&#039;}) &amp;=<br /> \Lambda^{-1}(x_A, t_A) =<br /> \Lambda^{-1}(-L, 0) \\<br /> &amp;= \left( \gamma (-L + 0(-u)), \gamma (0 + \frac{(-u)(-L)}{c^2}) \right) \\<br /> &amp;= ( -\gamma L, \frac{\gamma\beta L}{c} )<br /> \end{split} \end{equation*}<br />
The last point necessary for the set up is that both the observer M and the observer M' set the origin of their respective time axes to the moment that M' passes M.
5) So far quantities such as L and \gamma L are, as Doc Al said, "position coordinate of an event".
To get the spatial distance in one dimension we can use the formula:
\Delta x = |x_1 - x_0|​
Thus the distances from the observer M to the points A and B are (in the embankment frame):
\Delta x_A = |x_A - x_M| = |-L - 0| =\ L
\Delta x_B = |x_B - x_M| = |L - 0| =\ L​
and thus as I said in the previous post, "each half of the train measured in the embankment frame is also length L (so total length 2L)"
And the distances from the observer M' to the points A' and B' are (in the train frame):
\Delta x_{A&#039;} = |x_{A&#039;} - x_{M&#039;}| = |-\gamma L - 0| = \gamma L
\Delta x_{B&#039;} = |x_{B&#039;} - x_{M&#039;}| = |\gamma L - 0| = \gamma L​
and so, again as in the previous post, "the rest length of each half of the train, i.e. the length measured in the train reference frame is indeed \gamma L"
I'll leave off for now, the third assertion of my previous post will have to wait for next time.
  • #83
They are the lengths from the midpoint to the ends. If we're talking about the rocket scenario we can use Janus' rod attached to the rocket, which measures 300,000 km. This will give the rocket a length to measure in its frame if it needs one. The train is already this length from midpoint to the end.
Yes.
Not exactly right. They can't be applied to a single point. In the case of length contraction you need the beginning and ending coordinates of the length to be contracted. Einstein gives the beginning coordinate as 0 for simplicity in the example he gives. For time dilation you also need two times to compare. T=0 and t=>0. A single point doesn't contain enough information to do anything with.
I don't know why you think I have missed that point. Jcsd set up coordinates for the M and M' systems at t=0 for both. Nothing has happened yet. I thought it was peculiar that he indicated that something had happened already in the M' system when no time has elapsed yet.
Well, there is no doubt that I have more to learn about them.
  • #84
Actually I was just pointing out that I thought zoobyshoe was interpreting the \gamma L in jcsd's equations as the length L as measured by the train. This is not so.
\Delta x_A = |x_A - x_M| = |-L - 0| = L
\Delta x_B = |x_B - x_M| = |L - 0| = L​
Maybe I'm misinterpreting your notation, but \Delta x_A = |x_A - x_M| = |-L - 0| = L is the distance--as measured in the embankment frame-- between the events (A) A flashes and (M) M' passes M. Of course, since these events are simultaneous in the embankment frame, then this is a length. It's the length between point A and point M in the embankment frame, which was of course given as L. I don't see this having anything to do with the length of the train. (Was that even specified?)
Now you are measuring the distance between those events (A) & (B) and (M) according to the train frame. \Delta x_{B&#039;} = |x_{B&#039;} - x_{M&#039;}| = \gamma L is not the length L (between A and M) as measured by the train, since these events are not simultaneous in the train frame. I suppose that if (for some unknown reason) the ends of the train happen to coincide with locations A and B when the lights flash, then \gamma L would be the proper length of half the train. (Is that what you are assuming?)
  • #85
So, I just looked through Plover's post about the Lorentz Transforms, and he makes a case I can't follow for jcsd having used the correct formula under the circumstances. Not having the patience to try and inform myself about that particular application of the transforms at this point, I will simply stipulate he is correct, apologise to jcsd for having asserted he used the wrong formula, and try and get back to the question that started this.
Employing jcsds method, and given a speed of .5c for the ship or train, what will be the relative times and distances from t=0 for the detection of the light signals by the observer on the train or ship?
  • #86
In the train gedanken, L is the length from one light to the point M in the embankment. It is not the length of the train. (I guess it could be, but that would be just an arbitrary coincidence.)
Thanks for the lecture, but once a common origin is defined the LT can certainly be applied to a point (an event in space-time).
The two systems agree that the M clock and the M' clock both read t = 0 at the instant that M' passes M. That's all. They certainly do not agree that the lights flashed at the same time. At time t=0, the train frame says light B already flashed and light A didn't flash yet. But the embankment insists that both lights flashed at t = 0.
  • #87
The length of the train is 2L. Always has been.
Point, as defined by plover, yes, you may well be right. However, he/she may simply have made that whole post up. I certainly don't trust anything he/she says farther than I can throw it. The "uncontraction" post where the length "uncontracts" to one larger than it had before has made me suspicious.
Yes. This is absolutely what Einstein has said. However, I still don't know by what math we discover the difference in the reception time of the flashes by M'.
  • #88
Yes, this was my intention. Since L was introduced as a coordinate, I was just making the derivation of how it also ends up as a length.
Over the course of the thread, the assumption that the length of the train as measured in the embankment frame is the same as the distance from A to B has drifted in and out of use. The assumption is not present in Einstein's original set up, and in fact is implicitly denied by both Einstein's diagram and the one I gave in an earlier post. I should have been explicit that I was using it here.
If it appears that way, I expect its because I forgot to make the assumption about the length of the train explicit.
Yes.
Well, there's someone standing at each end of the train holding a pointy metal pole, and as it's the middle of an electrical storm, these someones must be fairly gullible, and, well, being one of those ubiquitous "assistants" that show up in gedanken-experiments always has been a thankless job... :wink:
  • #89
When do the photons arrive at M'? Here's when.
Ask nicely and we'll tell you. :smile:
Let's be clear. I'll define two events:
(1) photons from light B arrive at M'
(2) photons from light A arrive at M'​
According the to the train, these events occur at:
(x_1&#039;, t_1&#039;) = (0,\frac{\gamma L}{c} - \frac{\gamma v L}{c^2})
(x_2&#039;, t_2&#039;) = (0,\frac{\gamma L}{c} + \frac{\gamma v L}{c^2})
Note added: The order of the lights in my set up is A, M, B. M' moves towards B. So event #1 occurs before event #2 in both frames.
  • #90
Incidently, when we multiply gamma times length and get 346,410.15 and -346,410.15, what do these numbers tell us about A and B in relation to M, other than that they are still equidistant from M?
  • #91
No, That's not right.
Let's try this again with the following attachment.
Assume two very long trains. each car is 20,000 km long, as measured from the train to which it belongs.
Train 1 has three observers, M, A and B, A and B are 300,000 km from M, according to M, which puts them 15 cars away from M.
Train 2 is moving at .5c relative to train 1. It has observers M', A' and B'.
A" and B' are each placed an equal distance from M' such that from the frame of M, A and B, when M and M' pass each other, A' passes A and B' passes B. since train 2 is length contracted according to train 1, this places A' and B' about 17 cars away from M' on train 2. This means that the distance between A' and M' (or B' and M') is 346420 km according to train 2.
Now look at what happens according to train 2. A' and B' are a little over 17 cars from M' (this has not changed) putting them 346420 km from M'
A and B are still 15 cars from M, but since train 1 is length contracted according to train 2, each of these cars is only 17320 km long, meaning that A and B are, according to train 2, only 259800 km from M.
When M passes M' A' does not pass A and B' does not pass B.
so if the rocket measures the distance as 300,000km in its frame, the station does not measure it to be 300,000km in its frame.
  • #92
I assume you are talking about the \gamma L that appears in these equations:
B\&#039;\; = (\gamma L,\frac{-\gamma\beta L}{c})
A\&#039;\; = (-\gamma L,\frac{\gamma\beta L}{c})​
(I just noticed that jcsd defined the lights opposite to the way I would. In my set up, the lights are arranged in order A, M, and B. M' moves towards B. I hope this doesn't add any confusion.)
If so, then you must understand what they mean. These are the space-time coordianates according to the train frame of the events (A) light flashes at A and (B) light flashes at B. They tell us that:
- when light A flashed it was at position x&#039; = -\gamma L in the train frame
- when light B flashed it was at postion x&#039; = \gamma L in the train frame​
Yes, those flashes occur at postions that are equidistant from the midpoint M' of the train (but they occur at different times).
  • #93
Somewhere back there I gave the distance A---->B as 600,000 km. That's in the embankment frame.
I have also given the train a length of 600,000 km in its own frame wherever I mentioned a length for the train.
This means that when the train is at rest in the embankment frame they both measure 600,000 km.
When the train is moving at .5 c, it still measures itself to be 600,000 km long. The distance A--->B in the embankment frame, is still measured to be 600,000 km long in its frame.
If the train measures the embankment while moving at .5 c, it is, of course a different story. The moving train will see the distance A--->B contracted from 600,000 to .8660254% of that which is 5196152.4 km.
If an observer in the embankment frame measures the train, it will find the train to have contracted to 519,615.4 km, as well, from the embankment viewpoint.
If we need to demonstrate the same for the ship example for any reason we can do so by attaching your rods, provided the rods give it a length of 600,000 km in its own frame.
  • #94
That's right.
Nope.
OK. This is exactly what I thought. However, what confuses me is that 346,410.15 km is a greater distance than 300,000 km. I would expect it to be contracted, not lengthened. Of what use is it to apply the time dilation equation to a length? What does this help us understand about the situation?
  • #95
You are still thinking that \gamma L is the length L as measured by the train. It's not. According to the train, things go like this: Light B flashes. Then, some time later, light A flashes. During that time the train is moving (of course, in the train frame, the train sees the platform move).
I'm not sure what you mean by "apply the time dilation equation" to a length, as I did no such thing. I applied the Lorentz transformation to the space-time coordinates of an event.
If you wish to think of sticks shrinking and clocks moving slowly, then you apply the LT to sticks (lengths) and clocks. For example, a length of L in the embankment is measured to be L/\gamma from the train (yes, the train measures the lights A and B to be only 2L/\gamma apart); and the train frame will measure a time of \gamma \Delta t when an embankment clock measures only a time of \Delta t.
To analyze a problem correctly you need to apply length contraction, time dilation, and the relativity of simultaneity all together. That's tricky. The Lorentz transformation takes account of all of that for you.
  • #96
In the same online version of Relativity from which I've been quoting parts of chapter IX, Einstein gives the Lorentz transformation as:
x&#039;=\frac{x-vt}{\sqrt{1-\frac{v^2}{c^2}}}
y&#039;=y
z&#039;=z
t&#039;=\frac{t-\frac{v}{c^2}•x}{\sqrt{1-\frac{v^2}{c^2}}}
The two interesting ones, of course, are those for x' and t'.
In the next chapter, Einstein gives a simpler version of x':
^x(beginning of rod)^=0\sqrt{1-\frac{v^2}{c^2}}
^x(end of rod)^1•\sqrt{1-\frac{v^2}{c^2}}
"The distance between the two points being
If we want to express A or B as A' or B', it seems to me this is the one to use, multiplying it by the length, L, which is the distance between the two points (M--->B, or M--->A) in the embankment frame that we want to locate in the train frame.
Instead, jcsd used the next one referred to by Einstein; the one he uses to find the time dilation between two successive ticks of a clock. The first tick is t = 0. The second tick is:
t=\frac{1}{\sqrt{1-\frac{v^2}{c^2}}}
If the 1 in the numerator of the equation given by jcsd for \gamma is not the one used by Einstein in the time dilation version, I am quite confused about how jcsd arrived at the 1 from x-vt, which is the numerator in the more general equation for x'.
  • #97
Those are from this chapter:
Chapter 11. The Lorentz Transformation. Einstein, Albert. 1920. Relativity: The Special and General Theory
Address:http://www.bartleby.com/173/11.html
And the following one:
Chapter 12. The Behaviour of Measuring-Rods and Clocks in Motion. Einstein, Albert. 1920. Relativity: The Special and General Theory
Address:http://www.bartleby.com/173/12.html
  • #98
y&#039;=y
z&#039;=z
t&#039;=\frac{t-\frac{v}{c^2} x}{\sqrt{1-\frac{v^2}{c^2}}}
Yes, those are the same Lorentz transformations that jcsd and I both used. :smile:
^x(end of rod)^1 \sqrt{1-\frac{v^2}{c^2}}
Careful. This is not a "simpler version of x' ", it is a specific application to find how a length gets transformed when observed from a moving frame. Note that each end must be located at the same time.
If the problem is: Find out the distance from A to B as seen by the train frame, then that would be correct. But that's not what jcsd was calculating. Instead he (and I) calculated when and where those two flashes occurred according to the moving frame. That's a different problem. For one thing, those flashes occur at different times--so that length contraction formula doesn't apply.
jcsd used A to represent the coordinates of the event "Light A flashes" in the embankment frame, and A' to represent the coordinates of that same event in the train frame. (I'm not crazy about this notation, but that's what he used.)
How did we get the answers we did? It's easy. We know the coordinates of the events in the embankment frame, that's a given: x = -L, t = 0 (for A flashing) and x = +L, t = 0 (for B flashing). Now to find out when and where the train observers determine these flashes took place: apply the LT. Try this for yourself!
This is not what jcsd did. This particular equation describes the time dilation of a moving clock.
  • #99
This is a four dimensional version of the transformation I gave above. As it shows, spatial distortions happen only along the direction of motion (in this case along the x-axis). This is why the two dimensional system suggested by jcsd is useful.
Note: When Doc Al says: "jcsd defined the lights opposite to the way I would", he makes precisely the same change as I did where I said "I've switched the signs so that the train moves toward positive xm".​
The equation I gave was:
This is entirely equivalent to the separate equations:
x&#039; = \gamma (x - ut)
t&#039; = \gamma \left(t - \frac{ux}{c^2} \right)
(I expect this goes without saying -- I'm just ensuring the intention is clear.)
The notations introduced by jcsd (and which I should perhaps have reiterated):
\beta = \frac{u}{c}
<br /> \gamma = \frac {1} { \sqrt{1 - \beta^2} } = \frac {1} { \sqrt{1 - \frac{u^2}{c^2}} }<br />​
These notations are quite standard. Using u for the velocity in SR calculations also seems to be a current standard practice.
Again just to be clear, I'll apply these definitions to the separated equations above:
<br /> x&#039;\ =\ \gamma (x - ut)<br /> \ =\ \frac{1}{\sqrt{1 - \beta^2}} (x - ut)<br /> \ =\ \frac{x - ut}{\sqrt{1 - \frac{u^2}{c^2}}}<br />
<br /> t&#039;\ =\ \gamma \left( t - \frac{ux}{c^2} \right)<br /> \ =\ \frac{1}{\sqrt{1 - \beta^2}} \left(t - \frac{ux}{c^2} \right)<br /> \ =\ \frac{\left(t - \frac{ux}{c^2} \right)}{\sqrt{1 - \frac{u^2}{c^2}}}<br />​
These are obviously identical to the equations given by Einstein.
Note: There is a typo in Ch 12 of the Einstein. Near the end of paragraph 1 a sentence reads:
"For the velocity v = 0 we should have
\sqrt{1 - v^2/c^2} = 0​
and for still greater velocities the square-root becomes imaginary."
This sentence only makes sense if it is changed to read: "For the velocity v = c we should have...". (Someone should probably back me up on this.)
There is one issue that everyone has neglected so far (I think). Einstein's coordinate system diagram (in Ch 11) shows that the k system views the k' system as moving to the right, i.e. toward positive x. From the viewpoint of k', however, k is moving to the left, i.e. toward negative x. Thus if k measures the velocity of k' to be u then k' will measure the velocity of k to be -u. Similarly, if the x axes of the train and embankment frames are oriented to be positive in the same direction, then if an embankment observer measures the velocity of the train as u, an observer on the train measures the velocity of the embankment to be -u.
If I'm reading everyone correctly, jcsd and Doc Al took this into account (though I don't think they mentioned it). I, on the other hand, um, managed to make the issue disappear by making a calculation error when I applied the inverse Lorentz transform in my previous post, which I should fix (and which is probably why zoobyshoe found my argument for jcsd's values ambiguous...).
I assume it is agreed that the coordinates in the embankment frame for the event "flash at B" (which we are also taking to be the coordinates of "front of train passes B") are:
x = L
t = 0
If we insert these values into Einstein's equations (and reapply the standard notations), we get:
<br /> x&#039;\ =\ \frac{x - ut}{\sqrt{1 - \frac{u^2}{c^2}}}<br /> \ =\ \frac{L - u \cdot 0}{\sqrt{1 - \frac{u^2}{c^2}}}<br /> \ =\ \frac{1}{\sqrt{1 - \beta^2}}\ \cdot\ L<br /> \ =\ \gamma L<br />
<br /> t&#039;\ =\ \frac{\left(t - \frac{ux}{c^2} \right)}{\sqrt{1 - \frac{u^2}{c^2}}}<br /> \ =\ \frac{\left(0 - \frac{uL}{c^2} \right)}{\sqrt{1 - \frac{u^2}{c^2}}}<br /> \ =\ \frac{-1}{\sqrt{1 - \beta^2}}\ \cdot\ \frac{u}{c}\ \cdot\ \frac{L}{c}<br /> \ =\ \frac{-\gamma\beta L}{c}<br />​
So if we set u to .5c our value for x' is:
<br /> \beta\ =\ .5c/c\ =\ .5<br />
<br /> \gamma\ =\ \frac{1}{\sqrt{1 - (.5)^2}}\ =\ \sqrt{4/3}\ =\ 1.15<br />
<br /> x&#039;\ =\ \gamma L\ =\ 1.15L<br />​
Now since:
  • the origin of the x' axis of the train frame is the center of the train, and
  • the front of the train is at the point (x, t) that we transformed from the embankment frame
we know that the value of x' also equals half the length of the train. So at rest the length of the train is: 2 * 1.15 * L. Now why should this be so?
The train as measured in the embankment frame has length 2L. However, the train is in motion in the embankment frame, and thus appears contracted in that frame. So, since the value we started out with measures the contracted length of the (moving) train in the embankment frame, it makes sense that in the train frame, where the train is at rest, the length - no longer being contracted - is measured to be greater.
  • #100
zoobyshoe said:
Sophist.
_______________________________________________
:rolleyes: :confused: :rolleyes:
What are you talking about?
I used the word "uncontraction" to refer to the purely mathematical operation of finding the original length given a contracted length. When did I ever claim that something would be greater than its original length?
And what have I done that would lead you to countenance that I might intend such a reading? That makes a suspicion of willful deceit or "making whole posts up" more plausible than a mistake on one or both of our parts?
What's really going on here? (If you've got some beef, my pm box is open...)
