What if a chemical reagent reports purity as a range?
When determining which value to use for theoretical computations with a chemical reagent that has an assay range of 93.0% to 103.0%, it is advisable to consider the context of the calculations. Using the average value can provide a balanced approach, but calculating results using both the lower and upper limits of the range is also recommended. This method allows for a comprehensive reporting of results as a range, accommodating variations in the assay.
Baho Ilok
I have a chemical reagent that says:
Assay ... 93.0 ~ 103.0%
Which value should I use in theoretical computations? Should I take the average or the lowest value?
Thanks!
Chemistry news on Phys.org
Depending on the circumstances I would either go for the average, or I would calculate for both ends separately to report the final result of my calculations as a range as well.
Thank you so much!
It seems like a simple enough question: what is the solubility of epsom salt in water at 20°C? A graph or table showing how it varies with temperature would be a bonus. But upon searching the internet I have been unable to determine this with confidence. Wikipedia gives the value of 113g/100ml. But other sources disagree and I can't find a definitive source for the information. I even asked chatgpt but it couldn't be sure either. I thought, naively, that this would be easy to look up without...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
